Water pump fitting
Water pump fitting
Post  Chrs777 on Sun 30 Apr 2017, 1:43 pm
The two pipe fittings that bolt on to the tank top, one is for the water pump, and the other is for the bypass. Both fittings are brass and identical. But from where they bolt onto the tank top, one side of the fitting is about quarter inch longer... does the longest side of the fitting go above the tank top ??
Chrs777
Number of posts : 79
Re: Water pump fitting
Post  Mick1020 on Wed 03 May 2017, 10:55 pm
Hi, Longest side goes down thou the tank plate then fixing nut to secure fitting to plate
Mick1020
Number of posts : 65
