Tender paint
Tender paint
Post  Chrs777 on Mon 24 Apr 2017, 7:18 pm
I have got to the point that I am going to isoflex the water tank in tender. I don't have kit 8 yet, or the injector pipe bracket for the side of the tender.
Can I paint the tender or will I need to Wait till I have completed kit 8 which is tender fittings, and the pipe bracket ?
Chrs777
Number of posts : 79
Re: Tender paint
Post  JayBee on Mon 24 Apr 2017, 8:19 pm
I think that most, me included, have sealed the tender before fitting the accessories. You just need to make sure that you tape up all the holes or keep them clear. There will be some extra things that might need extra treatment after they are fitted but you will have the main sealing done and this will be simple then. Hope this helps.
John
JayBee
Number of posts : 84
Re: Tender paint
Post  Chrs777 on Mon 24 Apr 2017, 8:30 pm
That's what I'm thinking john.
Did you just primer and undercoat or top coat as well ??
I want to seal it up, as it may be a few weeks before I get kit 8 and the pipe bracket. Thanks for the reply.
Chrs777
Re: Tender paint
Post  lynnr on Mon 24 Apr 2017, 8:42 pm
I put wax plugs in the threads etc
Number of posts : 2956
Re: Tender paint
Post  Chrs777 on Mon 24 Apr 2017, 9:01 pm
So you did as well, seal up before kit 8.
Did you do primer plus undercoat, as well as top coat ?
Chrs777
Re: Tender paint
Post  JayBee on Mon 24 Apr 2017, 9:12 pm
Yes with mine I went the whole hog and did the final painting because I would have found it very difficult to get the linining on mine done if it was all assembled. I think that some of this depends on your colour scheme. I do have to be careful not to scratch it though.
John
JayBee
Re: Tender paint
Post  Chrs777 on Mon 24 Apr 2017, 9:29 pm
Thank you for your advice. 😊
Chrs777
Protecting threads
Post  Steve Traill on Tue 25 Apr 2017, 11:33 am
I've used the ends of cotton buds (with the plastic stalk) to protect the threads. Just cut the ends off and screw them into the small threads to keep them clean. They can be used several times before they are thrown away. Before spraying the cylinder block I used them a lot!
Number of posts : 720
Re: Tender paint
Post  Chrs777 on Tue 25 Apr 2017, 4:12 pm
Thanks Steve. I'll have to raid the wife's cotton bud section. .
Chrs777
Re: Tender paint
