Bonding the ends of the rubber tyres
Post  steamlaser on Fri 21 Apr 2017, 5:46 pm
I am ready to join the ends of the rubber tyres togeather. However as supplied the angle made when the ends are butted togeather are all wrong and will put the joint under strain if glued.
I have tried to file/mill the ends to make a match so one achieves a uniform circular shape, but to no avail.
I would appreciate any advice on the best method to use.
Many thanks.
steamlaser
Number of posts : 20
Re: Bonding the ends of the rubber tyres
Post  Mike King on Fri 21 Apr 2017, 6:10 pm
To be honest, I dont think you'll have a problem if you use a good quality superglue. I had the same issue as you and pressed ahead. I didnt alter the ends of the rubber, glued it, left for 24 hours. To prove the joint I just stood in the loop and pulled. No problem at all. The hardest part was fitting to the rims.
Number of posts : 311
Post  lynnr on Fri 21 Apr 2017, 8:25 pm
Clean the ends. Rough up with a sanding disk in the grinder. Fresh bottle of superglue (other brands are available). You can hang from it easily.
Number of posts : 2957
