Gauge glass
Gauge glass
Post  bazzer on Thu 30 Mar 2017, 12:02 am
Does anyone know the best place to get spare gauge glasses from?
Barry
bazzer
Number of posts : 182
Re: Gauge glass
Post  Simon B on Thu 30 Mar 2017, 5:24 am
Hi Barry
Try live steam models, on the website in the water gauge section, click on your gauge size and the glass is listed as an additional item, the glass comes in different sizes starting from 3.60.
Simon B
Number of posts : 126
Re: Gauge glass
Post  Steve Traill on Thu 30 Mar 2017, 12:29 pm
I use a short length of ally bar the same diameter as the glass to check all is well before fitting the glass. There's no second chances with them!
Number of posts : 720
Re: Gauge glass
Post  bazzer on Thu 30 Mar 2017, 3:55 pm
Thanks guys, the kit comes with a bar to line up the top and bottom.
bazzer
Re: Gauge glass
Post  lynnr on Thu 30 Mar 2017, 6:20 pm
I also cut the glass so there is only a couple mm inside the fitting. Just enough to stop the gland from slipping past when you tighten the nut up finger tight. This allows the fixture to flex without doing the glass and provides a good seal.
No broken glass in 4 years of many many hours and road miles. Had to replace due to corrosion at the ends otherwise no problems.
Number of posts : 2957
Re: Gauge glass
Post  bazzer on Thu 30 Mar 2017, 7:41 pm
Good tip Lynn, I will try that
bazzer
Re: Gauge glass
