Rivet screws on wheels
Post  steamlaser on Tue 07 Mar 2017, 1:56 pm
I have finally built my front and back wheels, but the spokes are currently held in by normal 3 mm nuts and bolts. How does one secure the proper round head rivet bolts whilst locking up the 3 mm nuts?
I will be putting a drop of "Locktite" on the threads of the rivet bolts, but fiddling on the tiny nuts will be a bit of a saga.
Many thanks
steamlaser
Number of posts : 20
Re: Rivet screws on wheels
Post  Mike King on Tue 07 Mar 2017, 3:06 pm
I held my rivet tops with a long nosed pliers, and i bent a small spanner to shape to be able to tighten. I also used loctite.
Number of posts : 311
Holding nuts for assembly
Post  Hamish Lonsdale on Wed 08 Mar 2017, 9:28 am
I found a short bar of mild steel (50mm) and drilled a hole into one end along its axis, just a bit larger than the nut diameter and 1.5 times deeper than the nut. I then put a small ball of Blu-Tac (a bit like plasticine but used in offices to stick paper to walls) into the hole. The M3 nut is then pushed in to the bar and is retained by the Blu-Tac, and the nut can then be positioned and the top of the thread located. It worked for me, and was of great help with the tender as well.
Best wishes,
Hamish.
Hamish Lonsdale
Number of posts : 9
Registration date : 2012-10-30
Holding Rivet Bolts
Post  steamlaser on Wed 08 Mar 2017, 11:42 pm
Thanks for the simple but practical idea of using Blue Tack in a shallow cup. This should solve the problem of trying to put on small nuts on fine threads that are also covered in Loc-Tight. Using long nosed pliers on the domed end of the rivet will give hopefully enough grip to allow proper tightening.
steamlaser
