superheater
superheater
Post  jjtjr on Sun 05 Mar 2017, 9:59 pm
After much steaming here in florida, I found that  water consumption is greater then predicted. What the problem seems to be is there is no superheat on our boilers. A friend here has a stanley and confirmed the problem. He also showed me a superheater design for our derr boilers. It uses 10' 0f  3/4"" by sch 80  pipe and will be mounted at the bottom of the tube nest closest to the burner. This will give the required superheat. I will be building it this spring and posting photos.
jjtjr
jjtjr
Number of posts : 117
type of steel
Post  jjtjr on Wed 22 Mar 2017, 1:22 pm
does anyone know the series of steel used in our boilers. Need to know for superheater. dean can have the info.
jjtjr
jjtjr
super heater
Post  jjtjr on Sun 28 Oct 2018, 1:34 am
Got around to making a super heater for the Derr boiler that's in our cars. It is made from sch 80 pipe and sch 80 weldable 90 des and 180 degs fittings. not quite finished yet. When finished it will 8 feet long and will be mounted below the tube nest so the burner flame will strike it. It is TIG welded using 7018 filler rod. The pipe used is 1/2".
jjtjr
jjtjr
super heater
Post  jjtjr on Wed 31 Oct 2018, 11:14 am
this is a good discussion on the building of super heater
https://steamautomobile.com:8443/ForuM/read.php?1,27985
jjtjr
jjtjr
Re: superheater
Post  jjtjr on Tue 06 Nov 2018, 2:48 pm
almost done
jjtjr
jjtjr
Re: superheater
