Rubber tyres for 2 inch Burrell
Post  steamlaser on Thu 9 Feb - 10:12
I have come to the stage of putting the rubber tyres on the front and rear rims.
The rubbers for the front wheels have been pre cut to leave a 60 mm Gap
The Rubber for the rear Wheels have been pre cut to leave a 80mm gap
Are these the correct gaps?
I have been told that normal super glue will not be strong enough to bond the ends togeather. Can anybody please me advise me on a suitable glue to use?
Many thanks!
steamlaser
Number of posts : 20
Re: Rubber tyres for 2 inch Burrell
Post  Mike King on Thu 9 Feb - 10:19
I just used a high strength superglue from ebay. The spacing on the rear wheels is around 5mm at the edges of the rims, that will set the centre gap. I hope thats of some help. Mike
Number of posts : 311
Post  lynnr on Thu 9 Feb - 12:10
I used normal superglue on my traction wagons and they have done a many hundreds of miles with loads in them and the joint has not split.
Number of posts : 2956
Tyres for front and back wheels
Post  steamlaser on Thu 9 Feb - 12:31
Thanks for the rapid response!
When the supplied ,unjoined tyres are offered up to the rims there are currently a 60 mm gap on the smaller wheel and a 80mm gap on the larger one. Is this correct?
When the ends are joined it will be a struggle to get completed tyres on the rims. There will be a great strain put on the bonded joints. Will the glue cope with the degree of stretch required?
steamlaser
Post  Steve H on Thu 9 Feb - 12:43
Just make sure the ends are clean and slightly roughened, use a good quality super glue gel and leave them alone once they are set.
You will be surprised how much they stretch,especially if they are warm, i left mine on the radiator for a couple of hours before fitting.
Good Luck
Steve H Very Happy
Steve H
Number of posts : 183
Post  Mike King on Thu 9 Feb - 12:46
I agree, they will stretch, especially with the isoflex.
Post  Ian on Thu 9 Feb - 12:48
They do need warming for a good couple of hours before fitting or they will not stretch sufficiently (radiator is best source of gentle heat)
It also helps to do the job in a warm environment while wearing disposable overalls, or really old clothes as its a mucky job.
Petrol is a dangerous but efficient solvent for cleaning up afterwards (outside maybe).
Number of posts : 104
Post  Robfishman on Thu 9 Feb - 22:47
To help stretch them on use cable ties to strap them to the rims as you work round it and stretch them on.  You'll need good strong ones or double them up as thinner ones will break.
Someone's posted this method a few years ago, can't find it at the moment, but I followed this on my water bowser and it worked a treat. I used isofix to stick them to the rims which helps also to slide them on.
