clack valve gaskets
clack valve gaskets
Post  bazzer on Sun 29 Jan 2017, 4:23 pm
Hi, can anyone tell me if the gaskets for the clack valves to boiler are supplied by STW, if so which kit are they in.
Barry
bazzer
Number of posts : 174
Re: clack valve gaskets
Post  lynnr on Sun 29 Jan 2017, 6:34 pm
Nothing supplied in the 4"DCC You have to make your own.
Number of posts : 2908
Post  TomBreeds Agricultural on Sun 29 Jan 2017, 8:40 pm
ant remember off the top of my head but i think it says to use the steam tight sealant stuff
Number of posts : 36
Registration date : 2014-12-03
Post  lynnr on Sun 29 Jan 2017, 10:21 pm
Gasket paper or Heldite liquid gasket. Just make sure the surfaces are flat to each other and the thinnest of jointing compound/material will do the job very well. Even a sheet of paper will work as a gasket done properly.
Post  Robfishman on Sun 29 Jan 2017, 10:33 pm
I used FLEXOID Gasket Paper for mine and the water pump etc. Not sure how it will perform though as only time will tell.
Post  bazzer on Mon 30 Jan 2017, 6:50 am
Thanks everyone.
bazzer
Post  LiveSteam on Mon 30 Jan 2017, 7:27 pm
My modelwoks 4" doesnt have the flattest of surfaces on many of its mating joints Laughing possibly because its a very very early one, anyhow I've found that Klinger Gasket Material I bought on E-bay works really well and since changing to this I have had zero issues, where as before I was always getting little annoying bubbly bits from places like the governor and safeties plates with anything else after a few steamings.
Number of posts : 467
