Metric or imperial
Metric or imperial
Post  Chrs777 on Fri 27 Jan 2017, 7:51 pm
Hi. Can someone tell me what type of spanners /Allen keys are needed for the build of a burrell agricultural ?metric or imperial ?
Also I'm interested to know what paints have worked best and where to purchase from ? I'm only going to be using black with some gold paint work on wheels. Is stove paint from b and q for the front end smoke box and chimney ? What type of paint to use on the rest ?
Chrs777
Number of posts : 79
Re: Metric or imperial
Post  Mike King on Fri 27 Jan 2017, 8:13 pm
I'm building the 2inch burrell, i have found that the majority of nuts bolts etc are metric. As your looking g at the 4 inch, the larger fixings may not be. I have used Craftmaster coach enamel, direct from Craftmaster. The black paint for smokebox etc, ive used Plastikote satin black bbq paint.
Number of posts : 311
Post  Chrs777 on Fri 27 Jan 2017, 8:17 pm
Thanks Mike. Have you used the craft master coach enamel on the boiler casing and tender / fire box ?
What about inside the tender ?
Chrs777
Post  Mike King on Fri 27 Jan 2017, 8:36 pm
Ive used the Craftmaster paint on boiler cleading, and the tender exterior. Tbe exterior of the firebox along ive used the plastikote paint. The interior of the tender is rubberised and sealed with isoflex. Once the top was put onto the tender tank, i used craftmaster.
Post  Robfishman on Fri 27 Jan 2017, 8:56 pm
I've also used Craftmaster coach enamel, but have used one shot paint for the red and gold lining.
Tools wise you'll need from 4mm to 13 mm in  the main, there are some larger but not many, Allan keys, a standard set will give you everything you'll need. All metric.
Post  Chrs777 on Fri 27 Jan 2017, 8:57 pm
Thank you for your replys.
Chrs777
Post  Chrs777 on Sun 29 Jan 2017, 9:27 am
Will I need primer and undercoat before the craft master coach enamel ?
Chrs777
Post  LazySmurfer on Sun 29 Jan 2017, 10:09 am
Chrs777 wrote:Will I need primer and undercoat before the craft master coach enamel  ?
2 coats of primer, 2 coats of undercoat, 2 topcoats. 2litres of each. Talk to them Smile
LazySmurfer
Number of posts : 74
Post  Mike King on Sun 29 Jan 2017, 10:31 am
And to finish it off. The superb Craftmaster varnish. Mike
Post  Chrs777 on Sun 29 Jan 2017, 10:59 am
Thank you.
Talk to the paint ? 🤔
Chrs777
Post  Mike King on Sun 29 Jan 2017, 11:07 am
Post  LazySmurfer on Sun 29 Jan 2017, 11:30 am
Chrs777 wrote:Thank you.
Craftmaster Razz I'm lucky their HQ is just down the road from me Smile
LazySmurfer
Post  Mike King on Sun 29 Jan 2017, 11:34 am
Ha!Ha! I get it. Anyway I hope that all goes well.
