'The boys' 4" Burrell Roller build
Page 3 of 3 Previous  1, 2, 3
Re: 'The boys' 4" Burrell Roller build
Post  NorfolkModelSteam on Mon 17 Sep 2018, 10:35 pm
Itís been rather a busy weekend!
NorfolkModelSteam
Number of posts : 86
Post  NorfolkModelSteam on Mon 17 Sep 2018, 10:38 pm
And a busy day today working on the cylinder and fittings.
NorfolkModelSteam
Post  bazzer on Fri 21 Sep 2018, 9:13 pm
Looking good.
Suggestion, don't forget to check the oil way for blockages, you can access it via the grub screw in the block, mine had a lot of swarf in it.
If I remember I used a 2mm allen key to clear and then a quick blast of air.
Barry
bazzer
Number of posts : 187
Post  Simon C on Fri 21 Sep 2018, 9:35 pm
Hi Greg
not sure if the above pictures are an observation test but you seem to have painted the inside of the front cylinder cover plate.
If you look at iso sheet 1 in kit 11A it shows the concave side outward facing worth a look before you assemble.
Simon C
Number of posts : 83
Post  NorfolkModelSteam on Fri 21 Sep 2018, 9:52 pm
Simon C wrote:Hi Greg
Thank you Simon! Been to the garage and had a look at the instructions, you are correct, will be busy with some wet and dry tomorrow evening!
NorfolkModelSteam
Post  Simon C on Fri 21 Sep 2018, 9:59 pm
I think that its only the paint on the spigot that might cause a problem to the fit.
S
Simon C
Post  NorfolkModelSteam on Fri 12 Oct 2018, 6:19 pm
NorfolkModelSteam
Post  NorfolkModelSteam on Fri 12 Oct 2018, 6:20 pm
My Junior Engineer is pleased with progress so far!
NorfolkModelSteam
Post  Steve Traill on Sat 13 Oct 2018, 4:59 pm
Looking very good, one happy little lad too!
Number of posts : 743
Post  NorfolkModelSteam on Thu 29 Nov 2018, 7:37 pm
Not much progress but a little!
NorfolkModelSteam
Post  NorfolkModelSteam on Sun 23 Dec 2018, 11:11 am
Work has started on the boiler and getting all of the components together! Hopefully a rolling roller by New Year!
NorfolkModelSteam
Post  NorfolkModelSteam on Tue 25 Dec 2018, 11:17 pm
NorfolkModelSteam
Post  NorfolkModelSteam on Sat 29 Dec 2018, 8:14 pm
Sheís a rolliní
NorfolkModelSteam
Post  Midwest Steam on Sun 30 Dec 2018, 1:57 am
Youíve been busy, keep up the good work!
Midwest Steam
Number of posts : 11
Registration date : 2018-09-19
