What oils to use and wicks?!
Post  Bryanh9904 on Thu 26 Jan 2017, 6:41 pm
Hi guys,
Just wondering what oil to use for each part?
I got a Woosted wool kit for Xmas, tried to fit it and it's Drained the oil pots!
Is it the oil I'm using (lawn mover engine oil for now as it was it the workshop!) or the wicks?
Any advice and pics of what other have done would be much appreciated
Bryanh9904
Number of posts : 92
Re: What oils to use and wicks?!
Post  lynnr on Thu 26 Jan 2017, 9:31 pm
The wicks are made like little rag dulls on mine and I use Hallett oils. The lawnmower engine oil is basically water to steam engines. Good for running in as it flushes through quickly. I don't remove the wicks between steaming as I prefer the after steaming drip through on to the dog training pads I use as drip sheets. This also confirms the action of the oiler wicks etc.
There is lots of articals online that show how to make them. I use bare copper wire from Maplin. Think it is about 0.25mm or something like that. Don't use any hard metals as if the wick gets down to the bearing or shaft it will not score or gawel.
After discussion with Hallett technical department they recommended the following.
Hallett
Bearing oil. LB460C.   25l
cylinder oil. SCO680CT. 25l.
The bearing oil is a good "golden syrup" in thickness when cold.
The cylinder oil is like molasses.
For cleaning I use
Locoklean. 22. 25l.
As it is good for cutting through the oil and grime without damaging the paint.
Number of posts : 3020
Post  MrStationHouse on Fri 27 Jan 2017, 1:11 pm
I use all the same as Lynn,
the lococlean is great stuff - better than parafin
Number of posts : 314
Post  LiveSteam on Fri 27 Jan 2017, 6:50 pm
If its the kit from heritage steam you'll have enough wool for decades, I made that mistake, but I now happily hand out hanks for others when the need some. I found the wire a little thick for our engines so just ended up using the earth wire stripped out from some 1mm twin and earth cable from memory.
As for oil I've been using Morris Universal steam oil in both bearings and the lubricator for over 2 years now and I'm very pleased with it, saves having to worry about the two different types. There was a member here who did a london to brighton run on a 4" showmans and they used it on that run and they were really pleased with its perfomance over this epic continous run.
Lyn you did those really good close up pics once of some wicks, I cant seem to find Embarassed might be useful to the OP
Number of posts : 533
Post  lynnr on Fri 27 Jan 2017, 7:09 pm
Found the oil dollies.
Road Loco
About half way down.
Post  LiveSteam on Fri 27 Jan 2017, 7:14 pm
Ah for got you did it for Mikes Road Loco Embarassed there was me hunting through Crystals build Rolling Eyes
Laughing Laughing
Post  lynnr on Fri 27 Jan 2017, 7:15 pm
at least you remembered that I did it in the first place.
Post  LiveSteam on Fri 27 Jan 2017, 7:49 pm
lynnr wrote:at least you remembered that I did it in the first place.
Believe me a lot of what you do I watch very closely and learn from for maintenance purposes as a owner driver rather than a builder.
Post  Robfishman on Fri 27 Jan 2017, 8:59 pm
I regularly look and your posts Lynn when I get stuck. Sometimes takes a bit of time but know it's there somewhere on one of the two threads.
Post  Bryanh9904 on Wed 21 Jun 2017, 3:55 pm
Thanks Lynn
Sorry for the late reply!!
Had to drain an axle box as was just drinking to the floor. Reseated and will put the right oil in and see how it goes.
Managed to get her in the garden in this heat so hers a few pics of my build so far 😁
Bryanh9904
Post  lynnr on Wed 21 Jun 2017, 4:01 pm
Lovely and brings back fond memories of my build.
