missing valve
missing valve
Post  bazzer on Wed 25 Jan 2017, 9:51 pm
Hello fellow builders, received kit 21 and have been test assembling various bits.
On the instructions it states, "fit 3/16 globe valve to top of steam head", there is no 3/16 globe valve in the box and it is not shown on the packing list, does anyone know if the valve should be there or does it come in another kit?
Also do STW supply the pipe to extend the left hand second shaft oiler above the water pump?
Many thanks
Barry
bazzer
Number of posts : 174
Re: missing valve
Post  TimV on Wed 25 Jan 2017, 10:23 pm
Hi Barry, the 3/16" steam valve comes in a later kit as does the 2nd shaft oil pipe.
Cheers Tim
TimV
Number of posts : 123
Re: missing valve
Post  bazzer on Wed 25 Jan 2017, 10:53 pm
Thanks Tim, can the steam head be fitted and the valve fitted at a later date?
bazzer
Re: missing valve
Post  TimV on Thu 26 Jan 2017, 9:08 am
Hi Barry. I wanted to fit steam head and to make it easier I used the blower valve for that as its the same type of valve and when the other one comes I will use it for the blower if you no what I mean ! Because if you fit steam head without valve then when you do try and fit it you will have to dismantle the valve as there is not enough clearance to turn it as it will hit the spec plate.
Cheers Tim
TimV
Re: missing valve
Post  Robfishman on Fri 27 Jan 2017, 1:26 pm
The Left hand 2nd shaft oil pipe is a bit of a pig to fit. Be careful when you go to fit it that it doesn't get hung up on the water pump ram or will likely get caught between it and the bolts and shear it in half when you turn it over, cutting it in half.
Re: missing valve
Post  bazzer on Fri 27 Jan 2017, 4:22 pm
Thanks Rob,
In will bear that in mind when the time comes.
Barry
bazzer
Re: missing valve
