Baffling (Help)
Baffling (Help)
Post  LazySmurfer on Thu 29 Dec 2016, 1:26 pm
Does the Baffle Plate bolt up against the Smokebox Door Boss or is there a gap? There are 4off M4 x 25 brass Rd Hd's for the job. The only M4 fasteners in the Kit they only need to be about 15mm long to do the job. Am I missing something here? Please help before I cut them down.
LazySmurfer
Number of posts : 73
Re: Baffling (Help)
Post  LazySmurfer on Thu 29 Dec 2016, 2:13 pm
M4 in as far as it will go. (anyone know that bloke, He said he was a BoilerMan but I'm not sure).
LazySmurfer
Re: Baffling (Help)
Post  Mark the spark on Thu 29 Dec 2016, 2:45 pm
on the showmans there is about a 10mm gap between them this is to shield the door from most of the heat
hot this helps
mark
Number of posts : 225
Re: Baffling (Help)
Post  LazySmurfer on Thu 29 Dec 2016, 2:53 pm
The 10mm gap being the boss or an extra 10mm gap & the plate rattling about ?
LazySmurfer
Re: Baffling (Help)
Post  Mark the spark on Thu 29 Dec 2016, 3:26 pm
there is aprox 10mm gap between the door and the plate and it is bolted tight If you look on my build thread in photos under Enchantress you will see a photo of my smokebox door
hope this helps
mark
Re: Baffling (Help)
Post  LazySmurfer on Thu 29 Dec 2016, 3:56 pm
Ok thanks Mark. Looks like I have to shorten the Screws then.
LazySmurfer
Re: Baffling (Help)
Post  T140 on Thu 29 Dec 2016, 9:03 pm
I had to shorten the scews to make them fit tightly.
Richard
T140
Number of posts : 37
Re: Baffling (Help)
Post  LazySmurfer on Thu 29 Dec 2016, 10:17 pm
Thanks Richard, cut about 10mm off them.
LazySmurfer
Re: Baffling (Help)
