Project 4" (1/3 Full Size) Burrell Agricultural Traction Engine Build.
Page 2 of 3 Previous  1, 2, 3  Next
Re: Project 4" (1/3 Full Size) Burrell Agricultural Traction Engine Build.
Post  Robfishman on Wed 01 Feb 2017, 8:04 pm
If I remember rightly those wheels are about 45kg, quite a lump to get on and off. Looking good though, keep the posts coming.
Post  LazySmurfer on Fri 03 Feb 2017, 6:59 pm
Yes Heavy & lots of work Smile
LazySmurfer
Number of posts : 74
Post  Jim the Shovel on Fri 03 Feb 2017, 7:21 pm
Have a look at my pics and you'll see my upside down roller skate. Works a treat especially when it comes to painting.
Happy building
Jim
Jim the Shovel
Number of posts : 100
Post  LazySmurfer on Sun 05 Feb 2017, 3:43 pm
Change of plan, I'm going to build a steam powered Penny Farthing now Smile
(Like the roller state idea Jim)
LazySmurfer
Post  NorfolkModelSteam on Sun 05 Feb 2017, 5:01 pm
Progress is looking really good! What did you use to clean up the wheels and spokes? I've seen a lot of people using patio cleaner and with flap wheels or polycarbide discs.
NorfolkModelSteam
Number of posts : 77
Post  Robfishman on Tue 07 Feb 2017, 11:26 pm
Looking good, I didn't worry that much about getting everything nice and shiny. So long at the parts are degreassed and there is no loose scale I was advised to to worry to much. I used a flap wheel to take the sharp edges off and to clean up any rough edges. By removing the sharp edges and rounding them just slightly painting will be easier as paint tends to not like 90 degree corners and will shrink back (not sure that makes sense but hope it does).
Anyway keep up the good work, and keeps the posts coming
Post  LazySmurfer on Sun 12 Feb 2017, 4:58 pm
Sunday 12th Feb '17 - All 16 spokes cleaned up, got it down to about 15minutes per spoke now. Grinder & Flappy things in a drill + a bit of filing. I did try patio cleaner on the spokes of one of the front wheels but it done bugger all, I think I my have brought the wrong stuff. Flappy wheels are great Very Happy
LazySmurfer
Post  LazySmurfer on Tue 21 Feb 2017, 4:24 pm
Tuesday 21th Feb '17 - I have top coat & its very PURPLE !
Is it ok to do a Traction Engine this colour ?
LazySmurfer
Post  Jim the Shovel on Tue 21 Feb 2017, 4:50 pm
It's your engine. You can paint it what ever colour you like. Same applies to the pinstriping.
The roller skate certainly pays off when your brush painting.
Jim
Jim the Shovel
Post  JayBee on Tue 21 Feb 2017, 5:51 pm
Looks good, not the most traditional but why not, It will look very impressive with some contrasting lining.
JayBee
Number of posts : 84
Post  NorfolkModelSteam on Tue 21 Feb 2017, 6:02 pm
Is this the 'Cadbury' purple I've seen on Facebook? Looks great!
NorfolkModelSteam
Re: Project 4'' [1/3 Full Size] Burrell Agricultural Traction Engine Build
Post  calimods on Thu 23 Feb 2017, 1:42 pm
What colour is that please, been looking at Plum/Purple for my 41/2'' Foden. Looks a nice colour. I have seen a 6'' Garratt 4CD in a similar colour. good luck with the build. Very Happy
calimods
Number of posts : 31
Registration date : 2010-07-21
Post  LazySmurfer on Thu 23 Feb 2017, 7:41 pm
Yes its the same colour as the Cadbury's Sentinel Steam Lorry, Craftmaster Paints will mix you up any colour you like Very Happy
LazySmurfer
Post  LazySmurfer on Fri 24 Feb 2017, 2:10 pm
Friday 24th Feb '17 - Kit 5. Unboxed & next to last months kit. No kit next month but I think I need that time to catch up. Lots to do & one hell of a lot of Painting !
LazySmurfer
Post  LazySmurfer on Sun 19 Mar 2017, 3:24 pm
Sunday 19th Mar '17 - Cleaned up a rear wheel rim today & put it in a coat of primer. The rims are a bit rough so I will use a bit of filler on them next. This is the first real work i've done on the engine in about 3 weeks as I got a piece of metal in my eye. It still not right but its on the mend now. If it happens to you go to A&E straight away, dont wait 2 days to let it go rusty in there like I did. WEAR YOUR GOGGLES ALL THE TIME !
LazySmurfer
Post  JayBee on Sun 19 Mar 2017, 5:05 pm
Glad to hear you are on the mend. Not a nice thing to happen and if they have to get it out with a needle not very pleasant at all.
Good luck,
John
JayBee
Post  LazySmurfer on Fri 24 Mar 2017, 3:33 pm
Friday 24th Mar '17 - Writing on the hup caps Smile , Potton is the town in which I was born & live.
LazySmurfer
Post  LazySmurfer on Fri 07 Apr 2017, 12:34 pm
Friday 7th April '17 - Kit 6a Number plates Very Happy
LazySmurfer
Post  LazySmurfer on Tue 25 Apr 2017, 2:46 pm
Tuesday 25th April '17 - Kit No7 for me but really Kit No9. Hornplates not the Tender. Lots of cleaning up, rivet fitting & painting to do.
LazySmurfer
Post  LazySmurfer on Sun 30 Apr 2017, 9:00 pm
LazySmurfer
Post  JayBee on Mon 01 May 2017, 7:20 am
You are really getting a move on with your build and it is starting to look impressive. Keep the pics comming it helps to spur us on.
JayBee
Post  LazySmurfer on Fri 26 May 2017, 12:54 pm
Friday 26th May '17 - My 8th Kit but Kit No 11a The Cylinder Block, was not expecting this until August ! Time to find that black bbq spray paint again Smile . Cant get it to load a photo Sad
LazySmurfer
Post  bazzer on Fri 26 May 2017, 6:31 pm
Don't forget to check the oilway.
Barry
bazzer
Number of posts : 183
Post  LazySmurfer on Tue 20 Jun 2017, 8:00 pm
As I can no longer work out how to put pics on here You can follow my build at :- https://www.facebook.com/pg/CODENAMEPOTTON/posts/?ref=page_internal
LazySmurfer
