Rear cylinder plate gasket
Post  bazzer on Fri 07 Oct 2016, 8:33 pm
Hi fellow builders.
I have a question.
I fitted the rear plate to the cylinder to align the hornplates, when I took the plate off I noticed that the gasket was only being sandwiched between the plate and cylinder face by a small amount is this correct?
A couple of photos to help explain.
bazzer
Number of posts : 182
Re: Rear cylinder plate gasket
Post  Mick1020 on Fri 07 Oct 2016, 10:30 pm
Hi Barry, The rear cyl cover is incorrect, there should be no raised lip, you will have to remove the lip or send back to stw hq for re-working or replacement, you will have to wait for this before checking the alignment of the hornplates
Mick
Mick1020
Number of posts : 74
Post  bazzer on Fri 07 Oct 2016, 10:37 pm
Thanks Mick,
I didn't look right to me.
I'll give HQ a ring on Monday.
Barry
bazzer
Post  bazzer on Thu 13 Oct 2016, 4:57 pm
Spoke to Steve this morning, he explained the cover I have is modded due an issue with some of the liners.
He is sending me the right one, so on with the build when it arrives.
Barry
bazzer
