Pitpup 2" tender painting.
Post  lynnr on Wed 21 Sep 2016, 12:16 pm
Hi Everyone
Got a small project in the workshop. Refinishing Pitpup's 2" agricultural engine tender.
Initial rubbing down then let to dry and see how the surface looks.
Little bit of macro
Now waiting for the paint to arrive.
Number of posts : 2981
Re: Pitpup 2" tender painting.
Post  lynnr on Fri 23 Sep 2016, 10:49 am
Ok here we go.
All masked off. Doing the outside first then remask and do the inside.
Just after spraying. The paint is starting to flatten out. Fingers crossed!
Starting to get nice and flat.
Post  lynnr on Fri 23 Sep 2016, 5:20 pm
Think it's looking quite nice.
Post  LiveSteam on Fri 23 Sep 2016, 7:53 pm
Nice work Lyn
I know where to send my cladding to now Wink
Number of posts : 525
Post  lynnr on Sat 24 Sep 2016, 6:39 pm
Little bit more progress done.
Painted the inside of the tender. Pictures taken the instant I put the gun down.
The masking is done on the edge only. So no masking tape or pressure on the new paint on the outside.
Post  lynnr on Sun 25 Sep 2016, 3:04 pm
Getting there.
Think this will do for the inside.
Post  wingman on Mon 26 Sep 2016, 10:45 pm
Great job there Lynn will you be lining it as well
John.
wingman
Number of posts : 57
Registration date : 2016-03-31
Post  lynnr on Mon 26 Sep 2016, 11:14 pm
No wingman. Just paint and trim the beading.
Post  lynnr on Wed 12 Oct 2016, 11:04 am
Bit more progress now my right wrist is healing after surgery.
Got a few sags and defects sanded out.
Couple areas of contamination showed up when spraying so rubbed back to primer.
Final (Hopefully) thin high gloss top coat.
I think it is looking good.
Once it has all hardened I will get the beading and tow hitch painted satin black as per request.
Post  lynnr on Wed 12 Oct 2016, 1:27 pm
Removed all the masking. I think it is looking quite good.
Hope pitpup is pleased?
Post  lynnr on Fri 14 Oct 2016, 3:15 pm
Well almost there.
Just a little bit of hand touch up to do on the black.
Masked off and ready. The clocks ticking as the red is still soft.
Oops! Its gone all black
Masking all off. Yes a couple of rips that need fixing but overall quite good.
Here is the "Oh bugger!" moment. But easy to fix once the rest is fairly dry.
Post  wingman on Sun 16 Oct 2016, 3:05 pm
Looking good there Lynn.
John.
wingman
Post  lynnr on Wed 19 Oct 2016, 11:12 am
Once the rain stops I will be finishing off the 2" tender. So there will be space in Crystals bedroom for another project.
Post  lynnr on Fri 21 Oct 2016, 10:30 pm
Almost finished. Bit of paint dust under the steps.
