Use of gaskets
Page 1 of 1 • Share •
Use of gaskets
Hi everyone,I have recieved kits 11A and 11b in the last few days and upon reading the build instructions it states that the use of the supplied gaskets is optional.
Just wondering what your thoughts are and if you went with or without gaskets and any problems if any with leaving them off.
Be good to get your feedback on this one.
Regards John.
Regards John.
wingman- Number of posts : 57
Registration date : 2016-03-31
Re: Use of gaskets
Hi John, as far as the valve chest is concerned, Steve advised me not to use the gasket, just use foliac, because this cover will undoubtedly be removed from time to time. I have used the gaskets on the actuually cylinder.
Mike King- Number of posts : 309
Re: Use of gaskets
Thanks Mike sounds like good advise what about the one between the cylinder and the boiler did you leave that out and foliar straight to the boiler.
John.
John.
Re: Use of gaskets
You definitely need that one. You need to use the foliac on that as instructed. All being well you should never need to remove the cylinder, mike
Re: Use of gaskets
Thought so,thanks Mike
John
John
» Header gaskets
» how to make gaskets
» Head Gasket Issues RR, RRC, D1 & D2
» Thimble-Drome .049
» Pee Wee Head gaskets
Page 1 of 1
