eccentrics catching
eccentrics catching
Post  Pitpup on Sun 18 Sep 2016, 6:56 pm
Hi everyone. Anyone had the problem of thier eccentrics catching the steam pipes below when the crank is turned ?.
P.S don't forget to check it my Burrell builders page on Facebook.
Pitpup
Number of posts : 108
Re: eccentrics catching
Post  Crazy_jim on Tue 20 Sep 2016, 5:38 pm
Yes mate. (On my build page you will see) it was a ball ache as I had to dismantle everything to get my sausage fingers inside and adjust.
Crazy_jim
Post  Pitpup on Tue 20 Sep 2016, 8:25 pm
Jim what was the final fix ?.....did you simply screw the elbow in futher?
Pitpup
Post  Crazy_jim on Tue 20 Sep 2016, 8:28 pm
Yes mate. enjoy!
Crazy_jim
Post  Pitpup on Tue 20 Sep 2016, 8:32 pm
Did you leave the lock nut off ?
Pitpup
Post  Crazy_jim on Tue 20 Sep 2016, 8:42 pm
Yep. Couldn't get the angle required with it on.
Crazy_jim
Post  Pitpup on Tue 20 Sep 2016, 8:47 pm
Let's hope it's steam tight then as after speaking with Steve he indicated it was needed to get a seal on the threads....I'm with you though....don't see how you can provide enough clearace with the nut on.
Pitpup
Post  Crazy_jim on Tue 20 Sep 2016, 9:13 pm
I've kept the nut. When I run on air if it won't hold pressure then I will file nut so it's a bit thinner and try that. My eccentric misses the elbow by a very very small tolerance.
Crazy_jim
