Boiler filling
Boiler filling
Post  Jamesd on Sun 18 Sep 2016, 9:20 am
I've just bought a secondhand 2" Burrell and I can't work out how to fill the boiler initially. Obviously it has the pump and injector for filling under pressure but what about the first time, is there a convenient filling point?
Jamesd
Number of posts : 5
Registration date : 2016-09-18
Re: Boiler filling
Post  lynnr on Sun 18 Sep 2016, 9:53 am
You should have a "bung" in the smokebox.
Also an option I use often. adaptor on the blowdown valve and put a hose on it to fill from the bottom.
Number of posts : 2915
Re: Boiler filling
Post  LiveSteam on Sun 18 Sep 2016, 7:13 pm
Blow down valve everytime on my 4" with a little submersible pump, although with a 2" its not going to take much water so an electric pump might be a bit much.
I filled a 3" the other day for a fellow chap on the rally field and it took seconds with my pump and just a few pints, where as the 4" gobbles 5 gallons with ease.
Number of posts : 483
Re: Boiler filling
Post  Jamesd on Sun 18 Sep 2016, 10:10 pm
Thanks both. When you say blowdown do you mean the small pipe on the gauge glass?
Jamesd
Number of posts : 5
Re: Boiler filling
Post  lynnr on Mon 19 Sep 2016, 8:46 am
One down the side of the horn plate at the foundation ring.
Re: Boiler filling
Post  LiveSteam on Mon 19 Sep 2016, 7:32 pm
I've nicked Its-me's picture and highlighted the bit on the boiler, you'll find a valve and outlet just there.
Hope that helps Cool
Re: Boiler filling
Post  Jamesd on Mon 19 Sep 2016, 11:33 pm
Extremely helpful, thank you.
Jamesd
Number of posts : 5
Re: Boiler filling
