The surrey
The surrey
Post  jjtjr on Fri 09 Sep 2016, 1:50 am
After 3 years it's done
jjtjr
jjtjr
Number of posts : 117
Re: The surrey
Post  killjoy on Fri 09 Sep 2016, 7:18 pm
Fantastic Job, well done.
killjoy
Number of posts : 5
Registration date : 2011-11-08
Re: The surrey
Post  Grier on Thu 15 Sep 2016, 4:12 am
Looks great! Can you tell us what and where you got your headlamp and how you mounted it?
Grier
Number of posts : 23
Registration date : 2015-05-15
head lamp
Post  jjtjr on Thu 15 Sep 2016, 11:37 am
I purchased the head lamp on e bay. then converted the lamp part to a modern high low beam bulb. the mounting of the lamp uses the headlight brackets that came with the light. and 1/2" bars bent and mounted the the spring upper plate. I will be shooting a you tube video on the car with detail and will post the link here.
jjtjr
jjtjr
Re: The surrey
Post  Stork on Sat 17 Sep 2016, 9:01 pm
Beautiful work jjtjr! Can't wait to see the video of her running!
Side note look what is coming up for auction:
http://www.bonhams.com/auctions/23555/lot/248/?category=list&length=100&page=2
And a Locomobile:
http://www.bonhams.com/auctions/23555/lot/243/?category=list&length=100&page=2
Stork
Number of posts : 33
Registration date : 2016-04-22
View user profile http://www.robertblanchard.co
surrey
Post  jjtjr on Thu 29 Sep 2016, 12:28 pm
This is the first of a few videos of the surrey walk around more will follow with detail. If there are any questions i will take more videos. Just let me know what parts you want the detail on.
https://www.youtube.com/watch?v=D-hzWokVKyA
https://www.youtube.com/watch?v=PCpkpcqCZoM
jjtjr
jjtjr
Re: The surrey
Post  Grier on Thu 29 Sep 2016, 10:11 pm
Hi jjtjr,
Could you show in more detail your speedometer set up. Specifically what gearing ratios were etc. to make it accurate.
Thanks,
Grier
Grier
Re: The surrey
Post  jjtjr on Fri 30 Sep 2016, 12:27 am
speedo setup
https://www.youtube.com/watch?v=vD1XE77WXk4
You have a 7.875 diameter blank. You wish to use a 7 diametrical pitch cutter. You want to cut 54 teeth on one gear and 40 on another. You want to have a gear ratio of 1.375.
54 teeth divided by 40 gives a ratio of 1.35 ?
52 teeth and 38 teeth, which gives a ratio of 1.3684. Which is closer to   desired ratio.
Gear blank size for 52 teeth 7 pitch is 7.7142
Pitch diameter is 7.4285
Cutting depth is .3081
Gear blank size for 38 teeth 7 pitch is 5.7142
Pitch diameter is 5.4285
Center to center distance should be about 6.4464 for the two gears.
jjtjr
jjtjr
Re: The surrey
Post  Grier on Fri 30 Sep 2016, 5:53 pm
SO if given a Model 26 with the 2.5 to 1 ratio that requires 1009 revolutions to the speedometer to equal one mile, and your above gear ratio of 1.375 then the wheel revolutions per mile would be 733.82. This translates into a wheel diameter of approximately 27.5 inches. Is this correct? I ask because I'm just waiting patiently for the next batch of Lykamobiles and don't have a wheel to measure.
Thanks,
Grier
Grier
speedo
Post  jjtjr on Sat 01 Oct 2016, 12:38 pm
I just measured my tires, yes the statement you made is  correct the diameter is 27" loaded with the weight of car on them,  A half inch of deflection is about right. Which gives you a diameter of about 27.5 give or take a little. I made the speedo  setup in 2011 so I had to look for my old calculations.
https://i.servimg.com/u/f97/15/83/69/23/img_0011.jpg
The cutter was dull after a few teeth.
I then made a new disc from cast iron which was much easier to machine. This is the steps that I followed.
https://i.servimg.com/u/f97/15/83/69/23/img_0012.jpg
https://i.servimg.com/u/f97/15/83/69/23/img_0013.jpg
https://i.servimg.com/u/f97/15/83/69/23/img_0014.jpg
The final result. It was a slow go without a DRO on my miller. I have one now on the miller so Its faster to do any work.
https://i.servimg.com/u/f97/15/83/69/23/img_0016.jpg
I use the speedo all the time when I drive the car. Don't want to get any speeding tickets. Ha. Ha.
I used an involute cutter you can also hob the gear.
jjtjr
jjtjr
making of a surrey
Post  jjtjr on Sun 02 Oct 2016, 12:25 pm
Here is a link for the making of the surrey. you can see the process from the beginning. Some of the photos are not in order, but its easy to see what was done first.
groups.yahoo.com    steamcarriages_II
https://groups.yahoo.com/neo/groups/steamcarriages_II
jjtjr
jjtjr
Re: The surrey
