Missing Gaskets!
Missing Gaskets!
Post  Underwoods on Fri 02 Sep 2016, 9:25 pm
Hi All!
Been a while but I'm now at the stage where I can crack on with building our C Type my Dad and I started a few years back.
*** I'm currently fitting the cylinder block to the boiler however I believe there could be a gasket missing between the curved plate that sits on the boiler (F41601-3-1?) and the block itself. I have the gasket that sandwiches between the boiler and this plate however. Having read through all the pages and scanned the Solidworks model I'm still left in the dark... ***
Our build has been on hold since STW took over Modelworks and due to other commitments. We did manage to obtain the majority of outstanding kits of which some contained various components from other kits due to manufacturing restraints at the time etc. Having started to delve through the boxes we have I do know we are missing the odd part here and there.
No doubt I'll be posting similar queries in the near future!
Underwoods
Underwoods
Number of posts : 2
Registration date : 2008-08-30
View user profile https://www.underwoods-steels.co.uk/home
Re: Missing Gaskets!
Post  phil gomez on Sat 03 Sep 2016, 6:10 pm
Hi underwoods.
STW changed the cylinder design sometime ago, it is now cast in one piece.
I do remember seeing pictures posted of the cylinder block in two parts on the forum but posted a long time ago.
Hopefully STW might be able to help - give Steve a ring, he is very helpful.
Phil.
phil gomez
Post  Underwoods on Sun 04 Sep 2016, 3:24 pm
Hi Phil,
Many thanks I'll try and get in touch with them. Off the top of your head do you know if any other parameter's were changed with the block? Or was it just the case of keeping the original design and casting it with the saddle plate as one component? If so I can make a gasket and carry on.
Will
Underwoods
Underwoods
Number of posts : 2
Post  phil gomez on Sun 04 Sep 2016, 4:56 pm
Hi underwoods.
Spoke to a gentleman today how is still building a model works foden wagon how said there is no gasket between the cylinder and the cylinder saddle he just used folic paste.
Hope this helps.
Phil.
phil gomez
