Foden pump
Foden pump
Post  gwr1475 on Thu 23 Jun 2016, 4:59 am
Just wondering if anyone has found a way to make the pumps on the fodens a little less noisy?
You can hear it the video
mark
gwr1475
gwr1475
Number of posts : 60
Re: Foden pump
Post  hartshaulage on Thu 23 Jun 2016, 6:26 pm
Haven't noticed mine making that noise, will have a look next steam up
Russ
hartshaulage
hartshaulage
Number of posts : 231
Re Foden Pump
Post  atomenter on Thu 23 Jun 2016, 8:52 pm
Hi Guys (and Gals)
My pump definitely clanks when putting into the boiler, not nearly as noisy when returning to the tank.  I put it down to the lift on the ball in the clack but I haven't investigated any further.  It has always been noisy and I have steamed about 560 hours now.  Important thing is that it works!!
Tom
Number of posts : 173
Re: Foden pump
Post  hartshaulage on Thu 23 Jun 2016, 11:10 pm
Just watched a video of mine running and yes it is a normal noise and i wasn't pumping into the boiler at the time, i think its the two balls int he pump that cause the noise
Russ
hartshaulage
hartshaulage
Re: Foden pump
Post  gwr1475 on Fri 24 Jun 2016, 5:17 am
I adjusted the lift on the ball to the rear of the wagon (less lift) I think it is that one that is making all the noise.
I wonder if anyone has tried a PTFE ball instead of stainless steel.
gwr1475
gwr1475
Re: Foden pump
Post  Kevster on Fri 24 Jun 2016, 8:52 pm
I have used nitrile balls in my 3 inch Burrell engine water pump for about 4 years now with no problems,I used the next size
ball up from the specified steel one .
Nitrile is ok for the pump but not recommended for steam.
Have a look see the biggest one you can get in without restricting the flow too much.
They have worked for me,you can get them from model engineering suppliers.
Hope this is of some help
Re: Foden pump
Post  gwr1475 on Sat 25 Jun 2016, 5:16 pm
Hi all, Thanks for the replies.
Kev where did you get the nitrile balls from?
Another question for the Foden guys. The third shaft is where the two chains meet, the stub shaft with two sprockets on it. How is yours lubricated, is there an oil pot or a grease fitting?
gwr1475
gwr1475
Re: Foden pump
Post  Kevster on Sat 25 Jun 2016, 5:57 pm
Hi Mark,
I think reeves ,live steam models,polly engineering do them and probably a few other
model engineering firms.
Hope that helps
Re: Foden pump
Post  gwr1475 on Sat 25 Jun 2016, 8:45 pm
Thanks Kev,
gwr1475
gwr1475
Re: Foden pump
Post  mikero on Sun 26 Jun 2016, 7:55 am
I cover my third shaft with grease when I fitted it and with the amount of grease that needs to be going round on the chains it should stay lubricated.
Number of posts : 257
Re: Foden pump
