What black paint for the boiler & Cylinder Block?
Post  SimonW on Tue 21 Jun 2016, 10:49 am
Just wanted to ask what type/whos black paint others are using for the boiler and cylinder block?
I know it says it doesn't have to be heat resisting, and I used the Plasticote VHT paint on the smokebox and chimney as suggested elsewhere on the forum, but I just want a good quality brushable paint for the boiler and cylinder block...
Any info gratefully received...
Surprised
SimonW
Number of posts : 5
Registration date : 2014-10-08
Re: What black paint for the boiler & Cylinder Block?
Post  chas12154 on Tue 21 Jun 2016, 11:16 am
Hi Simon, I used a brush on stove paint on both. The boiler and cylinder block will get very hot so a heat resistant paint would be recommended.
I have used Blackfriar Heat Resistant Paint, I used a Matt black but you can get a gloss too. The paint is very thin, you will need several coats but it is dry in about 20mins, then ready to re-coat.
It's the best one I have found, after trying various makes.
Hope that helps
Charlie
chas12154
Number of posts : 412
Post  lynnr on Tue 21 Jun 2016, 12:57 pm
Your block will only get to 193 at 180psi.
I use B&Q stove paint.
Number of posts : 2919
Post  Simon B on Tue 21 Jun 2016, 4:33 pm
Hi Simon
I used the normal craftmaster enamel paint. I was unsure so sought advice from HQ, hopefully it should be Ok as I've used the same paint albeit a different colour for the cylinder cladding, which touches and bolts directly to the cylinder, we shall see in a few months time Shocked
Simon B
Number of posts : 126
Post  Kevster on Tue 21 Jun 2016, 7:43 pm
Plastikote BBQ paint on anything that get hot or brushable high temp exhaust paint if you want to brush it on,works for me.
Post  LiveSteam on Tue 21 Jun 2016, 9:39 pm
Recently used this on the boiler and cylinder block on the Agri during a bit of renovating and I've been very pleased with it so far Cool
https://www.machinemart.co.uk/p/clarke-sp5-heat-resistant-stove-paint-matt-b/
Number of posts : 499
Thanks!!
Post  SimonW on Wed 22 Jun 2016, 8:02 am
Thanks very much for the advice.
Sounds like a heat resisting paint would be best for long term from what most of you are saying, so heat resisting it shall be!
A stove paint should do the job nicely....
Thanks again....
Very Happy
SimonW
Number of posts : 5
