brass cylinder stips
Post  lintonsteam on Fri 17 Jun 2016, 8:34 pm
hi was about to fit the 2 brass strips to my cylinder when I discovered the screw holes are meant to be 6ba yet the holes are 6mm any body else had this problem are am I doing something wrong
lintonsteam
Number of posts : 31
Registration date : 2013-10-07
Re: brass cylinder stips
Post  Simon B on Fri 17 Jun 2016, 10:43 pm
Hi Lintonsteam, there should be a pack of 6ba tapped M6 brass grub screws in the kit, insert the grub screws first and then fit the cladding and two brass strips using the 6 bra brass screws. I found the grub screws a bit long so filed them down a bit first, I also put a small slit with a hack saw in the grub screw to make it easier to tighten them into the block, there may be better ways to fit the grub screws but that's what I did.
I hope the above helps?
Best wishes
Simon B
Number of posts : 126
grub screws
Post  lintonsteam on Sat 18 Jun 2016, 12:45 pm
hi simon thanks for info didn't realise they were there since nothing on supply list or drawings about them and didn't receive the strips till long after the kit, teach me to look closer in future thanks again
alex
lintonsteam
Post  LiveSteam on Sat 18 Jun 2016, 7:21 pm
To put the grub screws in I suspect you'll find they will have supplied some 6BA nuts to go on the screws. I recently replaced all mine on the Agri as some had expired and snapped off and I got the grubs, the screws and some nuts and a note to say do the following to install them.
Fit a couple of nuts on a 6BA screw, wind the 6BA screw with nuts into the M6 grub screw and then lock it on with the 6BA nuts, wind the whole assembly into the cyinder head, then release the two 6BA nuts and wind out the 6BA screw leaving the M6 grub in the cylinder head.
Job jobbed Cool
Number of posts : 522
brass strips
Post  lintonsteam on Sun 19 Jun 2016, 7:10 pm
hi livesteam got most of them in except 1 don't know if the threads are damaged that take the 6ba screws but will figure it out thanks.
lintonsteam
