Rear spectical plate
Post  Pitpup on Sun 05 Jun 2016, 8:44 am
Hi...has anyone else gone to all the trouble of painting and fitting the rear spectial plate only to find that to hole that the sight glass pipe passes through is to small for that to happen ?. It beats me how these little but very frustrating issues get past the control model stage. It's going to be a real pain as the only answer I see is to remove the plate....enlarge the hole and repaint. Thoughts people. Evil or Very Mad
Pitpup
Number of posts : 108
Post  chas12154 on Mon 06 Jun 2016, 12:47 pm
Hi Pitpup, I haven't got that far yet,but hope I don't have the same problem.
Like you, Iv'e had a few problems that you would think should of been picked up with the building of the test engine.
I guess the problems come about, when they modify components or change the size of piping that the test model didn't have.
It is very annoying and frustrating when it happens.
Charlie
chas12154
Number of posts : 412
Re: Rear spectical plate
Post  IanR on Mon 06 Jun 2016, 8:49 pm
Hi Pitpup,
Been there, done that! Mine was the same, I only discovered it after paiting and fitting it. I did manage to enlarge th hole without too much damage to the paintwork so I just touched up he paint around the hole.
IanR
Number of posts : 93
Post  Pitpup on Mon 06 Jun 2016, 9:57 pm
It's hard to get into with the sight glass support in place...that also is painted so font really want yo remove it.
Pitpup
Post  IanR on Tue 07 Jun 2016, 12:40 pm
I did remove the spectacle plate for drilling. By the way I bought a step drill to enlarge the hole as I believe it is quite hard to get a true round hole with a normal twist drill in thin plate material. Good luck!
IanR
Post  ejparrott on Mon 13 Jun 2016, 9:05 pm
Step drill or cone drill, depending on what size hole you want. Step drills I've only seen in 2mm increments, cone drills give all sizes, albeit the thicker the plate the more noticeable the taper
ejparrott
Number of posts : 117
Post  mariserve on Tue 02 Aug 2016, 8:58 pm
About to fit the plates, etc. together.
Seems worth enlarging hole now - by how much do you suggest?
Peter
mariserve
Registration date : 2016-05-11
Post  Mike King on Tue 02 Aug 2016, 9:05 pm
Are you sure that the holes need enlarging? I thought that mine would need it after reading some of the probs. My pipework fitted with no hole enlarging at all. Maybe depending on the batch??
Number of posts : 311
