Final Drive Lubrication?
Post  hydro9 on Mon 23 May 2016, 4:57 pm
Fast approaching lighting the 1st fire in my BU4. I'm wondering about final drive lubrication and would welcome the opinion of more experienced builders/users.
Obviously oil is not practical for these gears because it's not going to stay in place which leaves me with grease.
These gears are exposed at the bottom beneath the gear guards (very near the ground) and I'm thinking that the grease is going to collect dust/grit, etc., which will become grinding past. Doesn't sound like a good thing.
Alternative is to just leave the gears dry. At least then any dirt will not stay put.
Is there a consensus on this subject? What do you guys do?
Chris
hydro9
Number of posts : 17
Re: Final Drive Lubrication?
Post  Mark the spark on Mon 23 May 2016, 5:30 pm
I have always used steam oil or 90 gear oil because it is thick and sticky but easer to clean off than grease
mark
Number of posts : 224
Post  lynnr on Tue 24 May 2016, 7:47 pm
On Crystal all I do is a good squirt of the steam oil before running for the day. Gives enough lubrication and does not gather grit.
With hundreds of miles on her clock the gears are fine.
Number of posts : 2957
Oil is best
Post  Steve Traill on Tue 24 May 2016, 8:00 pm
Any thickish oil put on the gears is best as it's self cleaning, I only grease gears when there is no access, like in the RL diff. Greasing the wheel bushes is a good idea as the oil soon runs out on the wheels picking up dirt in the process.
Number of posts : 720
Post  LiveSteam on Tue 24 May 2016, 9:17 pm
Same here, quick dollop of "universal steam" oil on the final drive cogs and diff is all I've done in 2 years and not so all seems fine.
Really want to avoid grease as it will just pick up every bit of dust and crud and turn it into a very effective grinding paste Shocked
As you're running you can generally tell when it needs another drop on them as they start to go a little shiney, well thats what I work on most of the time unless on a long road run, I just do the same as Lynnr.
Number of posts : 517
