painting inside tender
Post  mick 100 on Sat 07 May 2016, 8:26 am
has anyone painted inside there tender as all our isoflex has blistered up so having to remove it all , any help would be great .many thanks mick and Claire.
mick 100
Number of posts : 97
Registration date : 2012-10-13
Re: painting inside tender
Post  Mark the spark on Sat 07 May 2016, 12:27 pm
I used red lead in my loco tenders for 25 years without one problem but it is getting very hard to get and my last loco tender I used industrial red oxide paint and so far has been ok (now 5 years old )
I would pour the paint in and rotate the tender slowly and let the paint get into all the corners then pour out the excess and allow to dry for up to 7 days
mark
Number of posts : 206
Post  mick 100 on Sat 07 May 2016, 3:42 pm
thank you very much I will have to brush it on as our engine is up and running, have lost faith in isoflex many thanks mick and Claire .
mick 100
Post  TimV on Sat 07 May 2016, 9:34 pm
You need to use a product called Apexior 3, it is made especially for inside of water tanks. Isoflex is not designed to be submerged in water for long periods. You can obtain Apexior products from heritage steam
Cheers Tim
TimV
Number of posts : 123
Post  mick 100 on Sun 08 May 2016, 8:19 pm
thank you tim I will get in touch with them sounds great .
mick 100
Post  LiveSteam on Sun 08 May 2016, 10:02 pm
mick 100 wrote:thank you tim I will get in touch with them sounds great .
Its not cheap, if you need to share the cost I could do with some as my tenders fairly unwell, although I'm not sure I'll be able to clean up my tender well enough for it now ??
Number of posts : 499
Post  mick 100 on Sat 14 May 2016, 4:54 pm
thank you I would have done but when I started to clean it out it was not a pretty sight so it's paint time .
mick 100
Post  LiveSteam on Mon 16 May 2016, 9:46 pm
No probs, I think mines the same to be honest, so it will have to make do for this season and painty time in the winter.
