Hornplate alignment tool
Post  RMc on Fri 08 Apr 2016, 5:05 pm
Having got Kit 10 Crankshaft bearing housings in place I tried the alignment tool but after removing any corner burrs it does not fit in either housing. Its a very small amount - Should I just file edges until it slides into housings individually before getting to alignment process to make sure it slides in both ? I am assuming housings right size.
Any advice out there
RMc
RMc
Number of posts : 23
Registration date : 2014-11-26
Re: Hornplate alignment tool
Post  Mike King on Fri 08 Apr 2016, 5:11 pm
I had the ssme issue last week as it was only a few thou, I contacted Steve, he advised to file carefully off both ends until they fit snug. To be sure only file from the same face on each end. I filed the faces facing the cylinder. The tool fits perfect. The alignment is spot on.
Number of posts : 311
Hornplate alingment tool
Post  RMc on Fri 08 Apr 2016, 5:51 pm
Many thanks Mike - will do
Robert
RMc
Re: Hornplate alignment Tool
Post  chas12154 on Fri 08 Apr 2016, 6:33 pm
Hi, the alignment tool, which kit does it come with? I've had up to kit 11b, so far
Charlie
chas12154
Number of posts : 412
Post  Mike King on Fri 08 Apr 2016, 6:43 pm
Kit 12 the boiler part number BU 21224.
Post  chas12154 on Fri 08 Apr 2016, 7:15 pm
Thanks Mike, got a couple of kits to go yet then.
Charlie
chas12154
