2nd shaft tube assemble - kit 10
Post  Phil Uridge on Tue 05 Apr 2016, 8:38 pm
Is it me or is the 2nd shaft assemble twisted. The holes on the left are not inline with those on the right and the Diff Lock Assemble doesn’t line up with the slot in the flange. Mine is about 2mm off centre.
Is anyone else having the same problem?
Phil
Phil Uridge
Number of posts : 40
Re: 2nd shaft tube assemble - kit 10
Post  Mike King on Wed 06 Apr 2016, 9:49 am
Hi Phil, just a thought, have you mistakenly mounted it onto the water gauge bracket holes, which are further around the shaft.
Last edited by Mike King on Wed 06 Apr 2016, 9:56 am; edited 1 time in total (Reason for editing : spelling)
Number of posts : 311
Post  Phil Uridge on Wed 06 Apr 2016, 10:37 am
Hi Mike,
No definitely using the correct holes. On further examination it looks like to 7 bolts holes that holds the flange on are off centre by a couple of degrees. I notice that if I bolt it to the hornplates they are twisted ( not both vertical).
I think I should contract Steve but would be interested to hear if anyone else has the problem.
Could get round it by elongating the four bolt holes on the other end of the shaft and file out the diff lock slot but its not right.
Phil
Phil Uridge
Post  Mike King on Wed 06 Apr 2016, 10:42 am
Definately a job for Steve. Very strange though, as i am assuming you had kit 10 the same time as me last week, so the would i thought came from same batch. Anyway, i hope alls ok.
Post  Phil Uridge on Fri 08 Apr 2016, 10:54 am
Received a replacement tube from Steve today and it fits perfectly. Very Happy
Phil
Phil Uridge
Post  Mike King on Fri 08 Apr 2016, 11:57 am
Hi phil,
Great result!
