Wayshaft bracket allignment
Post  IanR on Thu 24 Mar 2016, 9:28 am
Hi all,
I'm having a bit of an issue with the weyshaft bracket alignment. If I get it right for the piston slides the valve rod is too stiff. If I adjust it so the valve slides easily the piston is too tight. Just wondering if others have had this and how best to get around it?
IanR
Number of posts : 90
Re: Wayshaft bracket allignment
Post  Robfishman on Sun 27 Mar 2016, 7:03 pm
Hi Ian I had great fun lining this up as well.  As well as the adjuster screws I also slightly elongated the bolt holes on the bracket.  This allowed me enough adjustment to get everything to line up perfectly, after a few hours of adjustment it now it turns over lovely.
Post  Crazy_jim on Tue 29 Mar 2016, 1:14 pm
It's a painstaking process to attach and line up. A few times I had to down tools and grab a beer as the thought of having to take it all apart to file off a few thou here and there was starting to grate.
Did you find that the plastic bushes were really tight?
Crazy_jim
Post  IanR on Wed 30 Mar 2016, 5:45 pm
Thank Jim. I've got it a bit better but st still not entirely happy with it. Will just have to keep fiddling with it!
IanR
