Cylinder Block
Cylinder Block
Post  chas12154 on Thu 03 Mar 2016, 7:26 pm
Evening all, Ive just started my cylinder block. Can anyone tell me if you get cladding, for the side of the block, where the whistle goes? I can see, from other photos, on here, you get two brass strips, for front and back of the side.
Why I ask, is the finish of that side of my block, is very uneven and wondered if I need to file it to get it more even.
Charlie
chas12154
Number of posts : 412
Re: Cylinder Block
Post  Mike King on Thu 03 Mar 2016, 7:40 pm
I am receiving my cladding tomorrow, im reasonably certain that cladding is supplied for this. If no one else has advised, I'll let you know tomorrow.
Number of posts : 309
cylinder block
Post  steam oil on Thu 03 Mar 2016, 7:55 pm
Hi Charlie
the cylinder cladding comes with boiler cladding
Steve (steam oil)
steam oil
Number of posts : 24
Registration date : 2013-11-09
Re: Cylinder Block
Post  Crazy_jim on Thu 03 Mar 2016, 8:59 pm
As above. It comes with the rest of the cladding later on. Don't worry to much about the machined finish on that side as it will be covered by the cladding.
Be warned though. As published on my thread you will have to cut down the brass screws and or run a ba tap down the threads in the block before fitting the cladding and brass strips. I snapped my tap inside the block and it was a (insert appropriate expletive) to get out.
Crazy_jim
Cylinder Block
Post  chas12154 on Fri 04 Mar 2016, 9:14 am
Morning, thanks to all of you that replied.
I did think you got cladding for that side of block.
Thanks Jim for that advise, I have already had to run a tap down some of the threads, as they wasnt threaded down the hole, far enough. I do remember reading your thread and seeing photo of the broken tap!
I too have broken a tap, but that was in one of my rear wheel hubs, STW sent me a replacement hub and wheels are done and painted now.
Hope all of you building a 2" are getting on well with your builds and enjoying the challenge Very Happy
Charlie
chas12154
Cylinder Block
Post  chas12154 on Sat 05 Mar 2016, 6:30 pm
Evening all, can I ask what you what paint you used on your cylinder block?
I can't seem to find a good brush-on heat resistant paint. The ones I have tried are like trying to paint with water!
Your help would be appropriated.
Charlie
chas12154
Re: Cylinder Block
Post  Mike King on Sat 05 Mar 2016, 6:43 pm
Hi Charle,
               I used 3 coats of Plastikote satin black oven paint. I sprayed the cylinder casings and covers before i assembled it all, and before i put the various plugs in, then cooked it. It looks good and feels hard wearing.
Last edited by Mike King on Sat 05 Mar 2016, 6:52 pm; edited 1 time in total (Reason for editing : spelling)
Re: Cylinder Block
Post  lynnr on Sat 05 Mar 2016, 7:38 pm
My 4" showman has one coat of stove satin. Still in good order after 3.5 years
Number of posts : 2908
Cylinder Block
Post  chas12154 on Sun 06 Mar 2016, 9:45 am
Thanks to you both for replying.
Mike, how long and with temperature, did you put it in oven for?
I'm a bit concerned about putting the block in the oven. I have, already, put the screw in, plugs in and painted one coat of paint on.
Lynnr, what make was the paint you used, was it "watery like" to paint with?
Charlie
chas12154
Re: Cylinder Block
Post  lynnr on Sun 06 Mar 2016, 10:47 am
Plastikot (B&Q) stove satin. On to bare metal and yes quite "wattery" a few light coats in quickish order. I did a bit of scrap metal and prodded it until it went tacky then did another coat and repeat until good coverage. No curing done until in steam.
Cylinder Block
Post  chas12154 on Sun 06 Mar 2016, 10:53 am
Thanks Lynnr, sounds like the sort of paint I have got. Will try what you have suggested and see what out come I get.
chas12154
Re: Cylinder Block
