Hornplate fitting
Hornplate fitting
Post  JayBee on Wed 02 Mar 2016, 6:27 pm
I am working on the hornplate assembly as rough assembly and would welcome a little advice.
Mocking up the assembly I cannot see how the hornplates fit to the tender. I have a dimension of 288mm on the inside of the tender but only 283mm on the outside of the hornplates at the rear. I cannot see how I will be able to pull the tender and tow straps in the 5mm. At the moment the tender sides are nice and uniform. Could someone please give me a dimension that I shoud be working to.
Also before I take the angle grinder to the front spectacle plate. To fit neatly I will have to trim the right hand side to keep the hornplates parallel.
John confused
JayBee
Number of posts : 84
Re: Hornplate fitting
Post  lynnr on Wed 02 Mar 2016, 6:48 pm
I would do nothing at the moment as the axial shaft housing and boiler will dictate the correct width.
Best also wait until the boiler is on site. Then if needed things can be adjusted. Everything fitted on crystal so not sure why you would have 5mm descrepencies.
Number of posts : 3023
Post  JayBee on Wed 02 Mar 2016, 7:09 pm
Thanks you are probably right, I have just been worried about having to destroy all the paintwork doing late on fitting. If that happens you may hear the scream of frustration from where you are.
Cheers,
John
JayBee
Post  lynnr on Wed 02 Mar 2016, 7:13 pm
When I fitted. I went right to left across the horns. Hung the right. Fitted all the cross parts. Then fitted the left. Tender slipped on.
Post  JayBee on Wed 02 Mar 2016, 7:40 pm
Its just difficult to see how the rear spectacle will work without there being a gap between it and the hornplate. I have history because I did have to do a bit of minor adjustment to one of the rear wheel to get the right amount of offset. Steve sent me some slightly longer spokes but in the end it was easier to modify the original ones.
I elongated the holes otherwise the hub was being pulled too far across.
John
JayBee
