injector fitting
injector fitting
Post  Tassie Tiger on Thu 25 Feb 2016, 11:02 pm
Hi everyone,
Have not been on the forum for a while and just trying to complete my engine hopefully and have come across a small problem.
The small piece of copper pipe with nuts that connects to the injector will not fit. One end is ok but the other end seems to have the wrong thread on it.
Anyone had this problem?
Thanks in advance.
Phil
Tassie Tiger
Number of posts : 47
Re: injector fitting
Post  lynnr on Fri 26 Feb 2016, 3:02 pm
Quick picture please.
Number of posts : 2906
Post  bazzer on Fri 26 Feb 2016, 5:02 pm
Hi Phil,
Do you mean where the pipe connects to the valve on the tender?
I had a modified valve in my tender fittings kit, could this be the problem?
Barry
bazzer
Number of posts : 174
[url=http://www.servimg.com/view/17152326/13][img]http://i84.servimg.com/u/f84/17/15/23/26/p1050610.jpg[/img][/url]
Post  Tassie Tiger on Sat 27 Feb 2016, 9:44 am
Thanks for your replies.
The part number that I am referring to is BU 42156 Injector to water valve pipe.
Hope the photo helps.
Phil
Tassie Tiger
Injector fitting
Post  Tassie Tiger on Sat 27 Feb 2016, 10:12 am
Sorry still trying to post photo Mad
Tassie Tiger
Injector fitting
Post  Tassie Tiger on Sat 27 Feb 2016, 11:02 am
This is the nut that is causing problems
Tassie Tiger
Post  Mick1020 on Sat 27 Feb 2016, 12:03 pm
Hi there, You have to contact STW as there is an upgraded water valve & fittings for this, i had the same water valve in my kit. Just give Steve Or Dean a call
Mick1020
Number of posts : 64
Injector fitting
Post  Tassie Tiger on Wed 02 Mar 2016, 4:46 am
Thanks Mick and Bazzer
Will contact STW for updated bits
Phil
Tassie Tiger
