oilerbracket
oilerbracket
Post  bazzer on Tue 12 Jan 2016, 6:13 pm
Hi fellow builders, hoping someone can help me.
I am assembling kit 8, hornplates.
In the instructions it states " two brackets BS42762 & BS42763 are attached to the inside flange of the rear spec plate, as shown on the ISO".
I have only got BS42762 and it doesn't show the position on the ISO.
Would anyone be able explain if I need BS42763 and the correct position or a photo.
Many thanks
Barry
bazzer
Number of posts : 174
brackets
Post  wren on Thu 14 Jan 2016, 3:50 pm
If you look at the back of the spec plate one bracket fits in the top hole left side and one bracket fits in the bottom hole right side
this all is in kit 9 sheet no 2 ISO 09A TITLE 2nd Shaft oiler brackets
Hope this helps
wren
Number of posts : 10
Registration date : 2014-04-10
Re: oilerbracket
Post  bazzer on Thu 14 Jan 2016, 5:15 pm
Thanks Brian,
But I only had one bracket on the packing list and only one ISO sheet.
I have contacted STW and Steve is going to get back to me.
Barry
bazzer
Re: oilerbracket
Post  bazzer on Sat 16 Jan 2016, 11:23 am
Steve has confirmed only need the left hand bracket.
bazzer
Re: oilerbracket
