2nd Shaft Oiling Provisions
Post  hydro9 on Tue 06 Oct 2015, 3:43 pm
Guys, I'm puzzled about the 2nd shaft oiling. I have two questions:
1) The RH angled oiler is totally different with no bowl/wick design, so how do we add a meaningful amount of oil?
2) The LH oiler is lost behind the water pump. There is a bracket on the rear Spectacle plate to elevate the oiler above the pump, but what pipe/fittings are provided to link between this new position and the original 2nd shaft tube threaded hole?
Any guidance would be most appreciated
Chris
hydro9
Number of posts : 17
Re: 2nd Shaft Oiling Provisions
Post  Mick1020 on Wed 07 Oct 2015, 9:46 pm
Hi Chris, use the oil bowl & fittings with the 90 elbow for the r/h side & the left side is in kit 24 which includes the oil pipe, hope this helps
Mick1020
Number of posts : 74
2nd Shaft Oiling
Post  hydro9 on Thu 08 Oct 2015, 7:47 pm
Hi Mick, Good idea to use the 'proper oiler' (with bowl and wick tube) at RH end.
I'm still stuck though, because my Kit 24 only contains 1x oiler bowl/tube/cover and that's needed for the governor.
No sign in Kit 24 of the extension oil pipe to reach up to the bracket either.
I guess I'll have to bounce this question off Steve at STW.
Best Regards
Chris
hydro9
