whistle on the engine
Post  wren on Sat 05 Sep 2015, 3:06 pm
      on my engine the whistle will not seal on the seat and the ball it leaks air out of the pin is this right ?  or should it seal and how can I stop this leaking ?
       Thanks for reading
wren
Number of posts : 10
Registration date : 2014-04-10
Re: whistle on the engine
Post  Grahambro on Sun 06 Sep 2015, 7:29 pm
Hi Brian,
Mine leaked on air so I fitted a stiffer spring. This helped but still leaked slightly on air but it's fine when in steam once pressure is above about 20psi.
Graham
Grahambro
Registration date : 2014-11-30
Post  LiveSteam on Sun 06 Sep 2015, 8:20 pm
I wouldnt worry too much about the odd leak here and there, once its in steam it nearly always will be fine.
You'll also get the odd weep as its coming up but quite often they will stop once you've got some heat in it Cool
I was a little worried about weeps here and there but my boiler inspector said its a steam engine, show me one that doesnt Laughing
Number of posts : 499
