New build of a Burrell
Page 3 of 3 Previous  1, 2, 3
lubricator
Post  bigship69 on Wed 03 May 2017, 7:54 pm
Hello I can see you have a different lubricator is the other one supplied no good.
bigship69
Number of posts : 3
Registration date : 2015-04-18
Re: New build of a Burrell
Post  Mick1020 on Mon 08 May 2017, 11:53 pm
bigship69 wrote:Hello I can see you have a different lubricator is the other one supplied no good.
Its the factory one supplied by STW & working fine
Mick1020
Number of posts : 74
Post  Mick1020 on Sun 28 May 2017, 7:26 pm
A video clip of steam powering a corn roller over the weekend,
Mick1020
Post  JayBee on Mon 29 May 2017, 9:13 am
Lovely to see. At shows there are plenty of stationary engines and even full size traction engines working machinery so very good to see. Anyone up for making a scale saw bench?
JayBee
Number of posts : 84
Windermere Kettle
Post  Mick1020 on Thu 17 Aug 2017, 7:46 pm
Hi to all, Just made the Windermere Kettle, a lot faster boiling than the gas camping stove & for those road runs when there,s no pub on route for the cuppa,
A few pics
Just a short video of running the kettle
Mick1020
Post  JayBee on Thu 17 Aug 2017, 8:42 pm
Nice job. What a good idea well executed.
JayBee
Post  Irish Burrell on Thu 17 Aug 2017, 10:49 pm
Looking forward to a cuppa in Castledermot now Mick!
See you then
Keith
Irish Burrell
Number of posts : 12
Registration date : 2016-02-16
Post  LiveSteam on Thu 17 Aug 2017, 11:04 pm
Lovely job you've done there Cool
I wondered about a running board mounted one as I've seen a few like that now but opted for a converted oldie worldie kettle that I ripped out the original electric element and wound in a copper coil and then run it via some rubber hose off the drain of the injector.
This gives us a good few pints of hot water every time in about 60 seconds for cuppas and washing up etc
Once the engines got 30psi on the clock in the morning we dont use the gas stove at all during the day Cool Best thing I've made for the engine.
Number of posts : 517
Post  Mick1020 on Fri 18 Aug 2017, 11:39 am
Keith, nice to have the old cuppa after the beer outside the pub on the Saturday in Castledermot, looking forward to the rally, see you there.
LiveSteam, Thats a good idea connecting the kettle with a hose, the extra bonus for mounting on running board is i,m adding weight to the front end which is a good thing on the Agri.
Those small gas stoves have a hanger for the gas cylinders, was using about 3 cylinders for a 2 day rally
Mick1020
Post  LiveSteam on Mon 21 Aug 2017, 9:04 pm
Yeah I need to either add some weight to mine or lose some from me Laughing trouble is all these dam real ale tents at the rallys Laughing
I know what you mean by getting through gas, we use to do a small propane bottle in the caravan every two to three rallys, since making the windermere we have just used our first bottle this season Shocked thats about 10 rallys I think.
Post  Mick1020 on Mon 21 Aug 2017, 11:34 pm
LiveSteam- I,m in two minds at the moment to build a double seat with jockey wheels to take the weight off the engine
Mick1020
Post  LiveSteam on Tue 22 Aug 2017, 10:47 am
Mick1020 wrote:LiveSteam- I,m in two minds at the moment to build a double seat with jockey wheels to take the weight off the engine
I've seen a few of the jocky wheel options, it does seem you have to get it just right and it can be a little un nerving having the seat move independantly of the engine I've heard.
I've ummmed and ahhhed about doing it, half of me would like to so the Mrs's can ride with me, but since aquiring a fairly close coupled side by side twin seat two wheel trailer I've moved away from it as this has proved far more useful as I can carry enough coal and water on it to do a moderate road run of several miles without the need to hook up the larger 4 wheel trailer and I can sit on it next to the Mrs's at the beer tent in reasonable comfort rather than perched on the engine.
Winter Project
Post  Mick1020 on Wed 23 Aug 2017, 7:39 pm
Hi to all, Just received set of wheels for my winter project of building a heavy haulage trailer, will start a build thread when i make a start on it.
It won't be as fast of a build as my timber trailer was due to being in a rush, but will make steady progress
Mick1020
Gear Guard
Post  Mick1020 on Tue 26 Sep 2017, 10:10 pm
Hi all, made up a gear guard for the crank shaft gears, i know that the full size agri does not have this, but have noticed that when engine is running & stationary & there are children & adults looking , i have a fear that any lose clothing could get caught in the gears which would happen so fast & could result in injury, up to now then someone has been two close have stop engine, I may be a bit over cautious about it but you never know
A few photo's
for oiling gears a simple wing bolt to remove then lift cover
There's an added bonus as well which is no oil splatter, after a days road run the under side of cover was covered in oil
Mick1020
Post  Steve Traill on Tue 26 Sep 2017, 11:15 pm
I like it, looks good & practical! What's the black thing just above the nameplate? don't recognise the fitting!
Number of posts : 720
Post  Mick1020 on Tue 26 Sep 2017, 11:33 pm
Hi Steve, its a gopro mount, been trying it out with videoing road runs, was thinking about moving it to get a better picture thou
Mick1020
Road run
Post  Mick1020 on Fri 13 Oct 2017, 7:46 pm
Just a short clip of a hill climb on 6 mile road run a few weeks ago
Mick1020
Post  Mick1020 on Fri 16 Mar 2018, 10:30 pm
Just an update on another job, fire bars replaced with 10 x 20 bar
Mick1020
