New build of a Burrell
Page 2 of 3 Previous  1, 2, 3  Next
Re: New build of a Burrell
Post  Mick1020 on Tue 15 Sep 2015, 7:25 pm
Its been raining over here so no steaming, so have been busy with a few mods, the water gauge on tender just makes it handy to check, the seat i made up useing the kit seat, the kit seat was to high for me & it was attached on tender below the bunker, so thats why i changed it, the second gear fork i noticed that it would jam on shaft & you have to move back & forward to get it to move so i made up to brass bushes which made it a lot easyer to move.
Tell me what you think if a good idea or not
Mick1020
Number of posts : 65
Post  LiveSteam on Thu 17 Sep 2015, 8:40 pm
Mick1020 wrote:
Love the water gauge, this is exactly what I want to do on my 4" MW as its a pain not knowing where I am with tender water, may I ask what parts/bits you used to create it ?
Number of posts : 468
Post  Mick1020 on Sun 20 Sep 2015, 9:53 pm
Hi Livesteam, parts used for water gauge are 5/16 x 32 water gauge kit from Live steam models, i used a 6mm nylon pipe inside 8mm copper pipe which i cut slot out, you can use 6mm gauge glass, hope this helps. By the way the gauge kit is for a 1" scale so you do get 6mm glass but its only 3-4cm long.
Regards Mick
Mick1020
Post  LiveSteam on Mon 21 Sep 2015, 10:08 pm
Many thanks Mick, very useful.
Winter project Cool
Post  Mick1020 on Sun 27 Sep 2015, 11:05 pm
Hi, She had her 3rd steaming today, all went very well, the banging noise has gone so the reduced stroke on pump did the job, steam injector worked a treat, so off i went on a spin, most enjoyable the power she has is amazing even as new so this will increase it time, priming is reducing which is good news, in all it was a great day Laughing I forgot to take video as time just flew bye, next steaming.
The smell & sound took me back to Sellindge steam rally where I grew up in the village, i see that it no longer runs now, we even took the kids over to it when they were small when visiting family.
I do have one question to ask if any one can help, its about the big end oil cup, i noticed that oil is coming out of the hole in cap due to rotation force, would i use the cyl oil as its thicker,or is there another solution.
Regards Mick
Mick1020
Post  LiveSteam on Fri 02 Oct 2015, 6:54 pm
I dont think its anything to worry about, they all do it to a degree I think. Generally mines got oil splashes all over the place.
I use Morris's universal steam oil which I use both in the lubricator and all the bearings, I find it very good and saves having to worry about two different oils.
Post  Mick1020 on Wed 07 Oct 2015, 9:39 pm
Thanks for the info Livesteam
I've fitted a fine mesh to the inside of oil cap so that it should catch the oil droplets just like the oil breathers on some engines, hopefully it will do the job.
Mick1020
Post  Mick1020 on Wed 15 Mar 2017, 8:52 pm
A few jobs done over the winter, with include fitting bushes to the rear wheels, I drop the wheels over to Fergal's workshop for machining, He is building a 6" Samson at the moment,
First steaming of the year
Mick1020
Post  Mick1020 on Tue 11 Apr 2017, 10:41 pm
Hi to all, Just a few photo's of the trailer i'm building at the moment, will post more photo's on progress
Mick1020
Post  JayBee on Fri 14 Apr 2017, 5:35 pm
Nice to see, keep the pics. coming.
JayBee
Number of posts : 84
Post  Mick1020 on Tue 18 Apr 2017, 7:36 pm
Top section finished
Wheels & axle's next job to do
Mick1020
Post  LiveSteam on Tue 18 Apr 2017, 7:51 pm
Looking lovely Cool
I like the sprung draw bar idea.
Was it deliberate to make it so the sides were not removable as the first 3 photos show one hinge the other way round stopping the side from being slide off ?
Post  lynnr on Tue 18 Apr 2017, 8:02 pm
Steam Traction Worlds traction wagons are also sprung drawbar.
Number of posts : 2908
Post  Mick1020 on Tue 18 Apr 2017, 8:22 pm
LiveSteam, It was deliberate for the hinge's as thinking that i would not be removing them to make a flat bed but now as you have said i may change it round. Many Thanks for your comments
Lynn your right about the STW trailer, Its a great idea to take the load shock off the draw bar, I won't be making leaf springs for it at the moment as i don't have any sprung steel as i'm hoping to have it finished within two weeks for the first large steam rally over here
Mick1020
Post  LiveSteam on Wed 19 Apr 2017, 6:47 pm
Mick1020 wrote:LiveSteam, It was deliberate for the hinge's as thinking that i would not be removing them to make a flat bed but now as you have said i may change it round. Many Thanks for your comments
Ah I see, must admit my poor mans version home brew version of a similar design has the option to make it either a complete flat bed with just a head board or with head and back board, certainly I find it useful to be able to take the sides and rear off completely if needed.
Wasnt aware the STW draw bars have load shock springs, I should look closer Embarassed not sure how I could add that to my version as the turn table and draw bar are kind of all one unit, it is after all just a heavy duty garden centre type trolly which has been heavily modified with wooden hinged sides and a rear board, but at less than 300 with the mods and having the ability to carry +400kg I was pleased with how it worked out, mines just on pneumatic 400x8 wheels with roller bearings and find its fine without any springs on the axles. Its not as pretty as yours and the STW ones but fuctional and for the money and the speed I put it together I was quite pleased with the result, I'll have to grab a photo of it next time its out.
Post  Mick1020 on Sun 23 Apr 2017, 12:25 am
Hi LiveSteam,I will change the hinge's around would be handy to remove sides with out taking off hinge all the time
Up date on progress
Wheels
Axle's, next job to remove & paint
Mick1020
Post  Mick1020 on Sun 23 Apr 2017, 10:41 pm
Undercarriage & wheels finished
Mick1020
Post  JayBee on Mon 24 Apr 2017, 7:47 am
That is all looking very good and progressing at a pace. Are the wheels new casting or recycled ones?
John
JayBee
Post  Irish Burrell on Mon 24 Apr 2017, 10:58 am
looking forward to seeing it at Shane's Castle this weekend!
Irish Burrell
Number of posts : 10
Registration date : 2016-02-16
Post  Mick1020 on Mon 24 Apr 2017, 8:11 pm
Hi JayBee, The wheels are old cast iron had a fair bit of cleaning done before taking photo
Hi Irish Burrell, I had a rush on to get it finished for Shane's Castle, looking forward to the rally
Mick1020
Post  Mick1020 on Mon 24 Apr 2017, 8:14 pm
Trailer Finished
Mick1020
Post  LiveSteam on Mon 24 Apr 2017, 8:25 pm
Wow you dont hang about, looks lovely Cool
Post  Mick1020 on Tue 02 May 2017, 9:07 pm
Few Photo's from Shanes Castle Steam Rally, engine + trailer
Pit stop for a nice cup of morning coffee
Mick1020
Post  JayBee on Tue 02 May 2017, 10:02 pm
Very nice work and done at such speed!!
JayBee
4" burrell agricultural
Post  bigship69 on Wed 03 May 2017, 7:41 pm
Great to see another burrell born . Can you tell me what comes in kit 23 is it only the lubricator on its own thanks.
bigship69
Number of posts : 3
Registration date : 2015-04-18
