Ronald G my 4" Agri
Page 3 of 3 Previous  1, 2, 3
Re: Ronald G my 4" Agri
Post  bazzer on Tue 16 May 2017, 6:15 pm
Thanks for you comments guys.
I will be posting a video of first steaming.
Barry
bazzer
Number of posts : 177
Post  bazzer on Fri 26 May 2017, 6:21 pm
Ronald G first steaming.
Couple of leaks to begin with but they sealed as he got warm.
Hope to have another go tomorrow, maybe drive around as well.
Barry
bazzer
Post  TimV on Fri 26 May 2017, 7:37 pm
Well done Barry
TimV
Number of posts : 123
Post  LiveSteam on Fri 26 May 2017, 10:31 pm
Lovely job, sounds very happy, nothing there that gives any cause for concern, bet you are really pleased with it.
Its funny how all the STW Agri's seem to have a certain sound I've found and they dont sound like other agri's (its not a bad sound by the way), and yours follows it perfectly. Can only imagine its all down to smoke box, chimney and exhaust giving it that distinctive hur huff hur huff hur huff sound they make.
Number of posts : 499
Post  mikero on Sat 27 May 2017, 8:13 am
The dog looks well impressed.
Mike Very Happy
Number of posts : 254
Post  bazzer on Sat 27 May 2017, 9:48 am
Yes Mike, bit of non-event as far as he was concerned.
bazzer
Ronald G ticking over on the drive
Post  bazzer on Mon 21 Aug 2017, 5:05 pm
bazzer
Post  Mark the spark on Mon 21 Aug 2017, 5:53 pm
very nice
Number of posts : 206
Post  LiveSteam on Mon 21 Aug 2017, 9:36 pm
Ahhhh lovely , but is it me or does it sound like its running a bit one sided ? theres only one real chuff, I'm fairly sure mine chuff's on both strokes because its double acting cylinder. might need a tweak on the valve rod when its hot.
Post  bazzer on Mon 21 Aug 2017, 10:11 pm
Do you mean it might not be opening on one port properly?
bazzer
Post  Mick1020 on Mon 21 Aug 2017, 10:50 pm
When the engine is fully up to running temp open the valve chest cover & move reverse lever into full forward & rotate flywheel in forward direction & check that the valve puck is opening the front & back ports by the same amount at the same 180 degree points on the rotation of flywheel e.g then you turn engine over & it just pass TDC or BDC you should just see the port by the same amount at both strokes,
if you set up the valve puck when the engine was cold then it will be out as boiler will expand in length when hot.
Hope this is of help I,m not that good at explaining things by writing them down
Forgot to say make sure the regulator is closed & wear gloves or its going to be a trip to the a&e dept.
Mick1020
Number of posts : 72
Post  bazzer on Mon 21 Aug 2017, 10:57 pm
Thanks Mick, will check that.
bazzer
Post  LiveSteam on Tue 22 Aug 2017, 10:32 am
Yep as Mick says, you can still hear it a little on the first video but it doesnt seem so pronounced which makes me think it was shot before everything was fully warmed up. I'm no expert in these things mind Laughing
Post  LazySmurfer on Sun 27 Aug 2017, 1:44 pm
Is your front cylinder cover plate the wrong way round ?
LazySmurfer
Number of posts : 71
Post  bazzer on Sun 27 Aug 2017, 5:28 pm
DOH!!!!  Embarassed
Perhaps that's where the problem lies with the exhaust note.
Will change around and check the port openings anyway.
Barry
bazzer
