Ronald G my 4" Agri
Page 2 of 3 Previous  1, 2, 3  Next
Re: Ronald G my 4" Agri
Post  bazzer on Wed 07 Sep 2016, 10:54 pm
Plasticote Satin black.
bazzer
Number of posts : 183
Post  bazzer on Tue 20 Sep 2016, 8:12 pm
Cylinder arrived.
Progress.
Saddle fitted.
Ready for paint.
Painted and cooking.
Ready to be fitted to boiler.
bazzer
Post  bazzer on Sat 15 Oct 2016, 10:51 am
Cylinder fitted to boiler
Horn plates  aligned
Steering sorted
bazzer
Post  lynnr on Sat 15 Oct 2016, 10:55 am
Looking good there. Nice to see progress.
Suggestion. Take a nice clear, clean closeup of the boiler build plate. It will help in the future for registration as the crank pit will become the black hole of Calcutta soon enough.
Number of posts : 2963
Post  bazzer on Sat 15 Oct 2016, 11:06 am
Thanks for suggesting that Lynn.
Will go and do it now before I forget.
Barry
bazzer
Post  parador on Sun 16 Oct 2016, 10:42 pm
Great pictures. Really interesting to see your build progress. Thanks for posting.
parador
Number of posts : 49
Post  bazzer on Sun 30 Oct 2016, 4:44 pm
Weighshaft bracket, slide bars and valve rod fitted.
Test fitting of cladding
Cladding primered
bazzer
Post  LazySmurfer on Sun 30 Oct 2016, 5:16 pm
Looking good Smile
LazySmurfer
Number of posts : 74
Post  bazzer on Mon 21 Nov 2016, 7:02 pm
Some more progress
Crank, Conrod, Piston fitted
Ronald G has got his clothes on
Diff fitted after a bit of fettling
Final drive test fitted
bazzer
Post  bazzer on Sun 04 Dec 2016, 4:07 pm
Ronald G's first look at the sun.
bazzer
Post  TimV on Sun 04 Dec 2016, 5:22 pm
Nearly there Barry, won't be long before you put a fire in !!
TimV
Number of posts : 123
Post  bazzer on Mon 06 Mar 2017, 7:38 pm
More progress
Reverser and gear guard test fitted
Reverser and gear guard painted and fitted
Gluing friction material to brake band
Brake assembly fitted
Steamhead and pipework fitted
Water pump painted, ready to be fitted
Gear change test fitted
New gear change plate made, holes in the original didn't line up
Whistle tuned and fitted
Gear change painted and completed.
Water gauge fitted
bazzer
Post  Mick1020 on Mon 06 Mar 2017, 8:19 pm
Engine looking great Barry, won't be long before first firing.
Mick1020
Post  TimV on Mon 06 Mar 2017, 8:27 pm
Well done Barry lots done, shall I bring round my compressor !!
TimV
Post  bazzer on Mon 06 Mar 2017, 8:54 pm
Thanks Mick, three more kits to go!!!
Tim, I have compressor, so end of next month should be able to try him on air. Video will be shot.
bazzer
Post  Jim the Shovel on Mon 06 Mar 2017, 11:13 pm
Nice work Barry. Looking good and not far to go now.
Looking forward to video of air run.
Jim
Jim the Shovel
Number of posts : 98
Short video of Ronald G running on air
Post  bazzer on Fri 14 Apr 2017, 7:35 pm
bazzer
Post  Kevster on Fri 14 Apr 2017, 8:34 pm
Very nice
Post  TimV on Fri 14 Apr 2017, 8:36 pm
Well done Barry, won't be long now
TimV
Post  poachermas on Fri 14 Apr 2017, 9:34 pm
Looking good Barry
Bye the way I ordered and received my name plates from David on your recommendation very pleased with them,so thank you
Marek
poachermas
Number of posts : 36
Post  lynnr on Fri 14 Apr 2017, 10:37 pm
Excellent work and progress. Sounding trick on air. She should be sweet as a nut in steam.
Post  bazzer on Sat 13 May 2017, 6:33 pm
Some photos of Ronald G now he is complete.
Hoping to steam for the first time next week.
Barry
bazzer
Post  JayBee on Sat 13 May 2017, 6:56 pm
Excellent, looks fantastic.
JayBee
Number of posts : 84
Post  Mick1020 on Sun 14 May 2017, 8:17 pm
Engine looks great Barry well done, the brown & green go together well, Don't know how you can wait another week before lighting a fire, there should be no problem in running as on air its running fine, the only problems you should check are steam leaks & pump, injector working to name a few but don,t get in a panic with steam leaks as if they are small as the steam pressure goes up those leaks will seal up, just take your time in firing with wood & have fun as always & good luck on its first firing
Mick1020
Post  LiveSteam on Mon 15 May 2017, 8:02 pm
Brilliant job and nice to see a Agri thats not over bling'ed. Cant wait to see it on the local rally scene around this neck of the woods soon by the looks of things Cool
Number of posts : 522
