Front wheels
Front wheels
Post  bazzer on Sat 23 May 2015, 5:49 pm
Started building my front wheels this afternoon, got to point where you have to put a rivet bolt in the centre hole and found that the rivet bolts are too long. Are there different length bolts for the back wheels? If so I may have been sent these by mistake. Any advice welcomed.
bazzer
Number of posts : 182
Re: Front wheels
Post  MrStationHouse on Sat 23 May 2015, 9:45 pm
I had to file all of mine flush with the nuts, used a power file which is an excellent tool for the build
Number of posts : 313
Re: Front wheels
Post  bazzer on Sun 24 May 2015, 12:02 am
They are not just too long,the thread doesn't go down far enough to tighten the spokes to the rim
bazzer
Re: Front wheels
Post  TimV on Sun 24 May 2015, 9:00 am
Hi Barry,
I think that you will find that the rivit bolts are all the same length for the front and back wheels, sounds like your T rings are slightly to thin maybe as all the spokes are generally the same thickness.
Probably best to have a word with Steve at STW
Cheers Tim
TimV
Number of posts : 123
Re: Front wheels
Post  bazzer on Sun 24 May 2015, 9:28 am
Thanks Tim.
bazzer
Re: Front wheels
Post  bazzer on Tue 26 May 2015, 9:04 pm
Emailed Steve, the rivet bolts were wrong size, he is sending me correct ones tomorrow.
That's good service.
bazzer
Re: Front wheels
