Front wheels
Front wheels
Post  Tom2015 on Sat 07 Mar 2015, 2:02 pm
Hi guys need your help
I have assembled my front wheel rims and isoflexed the tyres on last weekend what I've left hanging from the shed roof to dry since.. When is the best time or after how long can I mask up and paint my rims to prevent them going rusty? Any suggestions welcome many thanks tom
Tom2015
Number of posts : 35
Registration date : 2015-01-11
Re: Front wheels
Post  Steve H on Sat 07 Mar 2015, 5:47 pm
Left mine for about 2 weeks, but I used Sikoflex , but think you would be better off with them indoors, that will reduce the chance of moisture build up causing the rust.
Once mine were primed and dry I wrapped them in clingfilm to protect them, and put them away, as you won't need them for a while .
Steve H
Number of posts : 183
Re: Front wheels
Post  Tom2015 on Sat 07 Mar 2015, 6:01 pm
Thanks Steve will put them inside until next week what will be 2 wheels since I fitted the tyres before I mask up and spray as my wheels will be top coated and lined before putting away indoors
Tom2015
spoke fits
Post  Pitpup on Mon 09 Mar 2015, 8:18 pm
Hi...quick question. Has anyone had problems getting the rivit end of the spoke to fit flush with the rim ?
Pitpup
Number of posts : 108
Re: Front wheels
Post  Mike King on Mon 09 Mar 2015, 9:52 pm
Hi, i did have a similar issue. I found it better to loosen the hub bolts slightly on each spoke, then all fitted ok. They have been made to pretty tight tolerances
Number of posts : 310
rivet heads
Post  Pitpup on Wed 11 Mar 2015, 4:45 pm
Has anyone found a good way to produce a round rivet head on the inner rather than the nut finish ?. Looking at pictures of rear wheels they appear to be like it, front ones not ?
Pitpup
Re: Front wheels
Post  Mike King on Wed 11 Mar 2015, 5:04 pm
I used some araldite precision (the slow setting stuff) i dipped a thin drinking straw into it and let it run onto the head of the nut. It formed a bead, which when hardened off and painted, looks pretty authentic.
Re: Front wheels
Post  Pitpup on Wed 11 Mar 2015, 7:10 pm
Great advice mike....I'll give it a go...thanks.
Pitpup
Re: Front wheels
Post  Mike King on Wed 11 Mar 2015, 7:22 pm
Just lie the wheel flat. Put a small blob on top of the centre of the nut or whats left of the protruding bolt. If you are doing it in the house, it will start to even out. Any that spills down the side of the nut, take off with s blade, before its too hard. Obviously if powder coating, this would not cover.
Last edited by Mike King on Wed 11 Mar 2015, 7:25 pm; edited 1 time in total (Reason for editing : missed something out)
Re: Front wheels
Post  Pitpup on Thu 19 Mar 2015, 8:47 pm
Mike...do you have any pictures of the rivet heads that you formed with the glue ?
Pitpup
Re: Front wheels
Post  Mike King on Thu 19 Mar 2015, 9:18 pm
Although my wheels are now painted. I can send a pic to you. The only prob i have not had much luck with photobucket. If you can pm me with your email address i can upload you a couple of shots, if that helps.
Re: Front wheels
