correct paint? 2inch Burrell
Post  Mike King on Thu 19 Feb 2015, 3:08 pm
In the next couple of months i will be receiving the smokebox etc, although by reading the tips on the forum i realise that high temp paint direct onto the metal, then cooked in the oven. My query is with the smokebox door. With the brass having to have a etch primer, then i am assuming a high temp paint, then cooked. Will the etch primer be ok with this? Or have i misunderstood? Any advice appreciated.
Number of posts : 312
Re: correct paint? 2inch Burrell
Post  Simon B on Thu 19 Feb 2015, 3:32 pm
Hi Mike
I sprayed the smoke box door in its separate components, baked in the oven for a few hours then assembled. The brass parts were painted separately and then fitted, with the screws being touched up after assembly.
Hope this helps.
Simon B
Simon B
Number of posts : 127
Post  Mike King on Thu 19 Feb 2015, 3:37 pm
Thanks Simon,
Am i right in assuming then that the brass plate doesnt get as hot as the rest of it?
Post  Tony King on Thu 19 Feb 2015, 6:33 pm
If you're intending to do the name ring black & high light the lettering then go straight on with the high temp paint, you don't need to etch prime the brass!!
Post  Mike King on Thu 19 Feb 2015, 7:02 pm
Thanks Tony,
Much apprrciated,
