Chassis assembly question
Post  phil gomez on Thu 15 Jan 2015, 6:23 pm
The middle cross chassis member has 4 hole each side but the main chassis channel only has 2 holes on each channel for the Middle cross member. So my question is top 2 hole or the bottom 2 holes.
Is the middle cross member required for say the floor, I think it holds the under water tank in place.
Plus Should the cross member be level with the top of the main chassis or sits lower down?
Any ideas anybody.
Thanks.
Phil.
phil gomez
Post  atomenter on Thu 15 Jan 2015, 7:18 pm
Hi Phil,
This problem (or something similar) has already been mentioned during a previous batch of Fodens.  Can't find the post but I have attached a pic of how my chassis was put together.
Hope they help,
Tom
Number of posts : 173
Re: Chassis assembly question
Post  phil gomez on Thu 15 Jan 2015, 7:57 pm
Hi Tom.
Thanks for your reply and the pictures (very useful).
I can remember a post somewhere but can't remember where?
I have seen Russ and Nick & Ken build and both are at different heights? Shocked
Will the cab floor need the support of the middle cross member.
Phil.
phil gomez
Post  hartshaulage on Thu 15 Jan 2015, 8:29 pm
Hi Phil
I had the same thing with having 4 holes on the cross member and only two on the chassis, When i fitted mine i used the two top holes on the cross member.
The only thing that the cross member holds in place as i can see at the moment is the bottom water tank, and when i fitted mine i had no problems everything lined up and went in perfectly on the front and rear mounting brackets.
If you look at Nick & Kens you will notice they have the same as Tom all four holes used to mount there cross member in place and not like yours and mine only two
Hope This Helps
Russ
hartshaulage
hartshaulage
Number of posts : 231
Post  atomenter on Thu 15 Jan 2015, 9:45 pm
Hi Phil,
The rear tank bottom sits on the chassis side rails and I think the reason that the crossmember is slightly lower than the side rails is to allow clearance for the bold heads holding the centre tank in place (see below)
The bottom of the tank is really your seat.
Tom
Post  phil gomez on Thu 15 Jan 2015, 10:03 pm
Hi Tom.
Thank you again for taking the time to answer my question.
That would made sense.
Thanks again.
Phil.
phil gomez
