Best way to hold rivet bolts
Post  RMc on Sun 07 Dec 2014, 4:16 pm
How do you hold dome heads of rivet bolts as you tighten the nuts ?
RMc
Number of posts : 23
Registration date : 2014-11-26
RE how to hold rivet bolts
Post  Mike King on Sun 07 Dec 2014, 4:36 pm
Hi, I have just done mine, on the odd stubborn one i used a pair of small long nosed pliers, with a touch of Loctite thread sdhesive on the threads. Most of mine tightened up with just pressing against the rivet head while i tightened the nut with a spanner. It may work for you.
Number of posts : 309
Re: Best way to hold rivet bolts
Post  Steve H on Sun 07 Dec 2014, 7:37 pm
Buy a set of nut spinners, got mine at local model shop, you will find them invaluable
Steve H
Number of posts : 181
Best way to hold bolt rivets
Post  RMc on Tue 09 Dec 2014, 5:19 pm
Thanks Mike and Steve working on that. I did not know "spinners" existed I have been using my small socket set but its too clumsey to get into corners spinners look more useful.
RMc
Post  Mike King on Tue 09 Dec 2014, 6:47 pm
I found the rivets that need the nuts on the inside of the rim are difficult. I actually put some super glue under the heads when i pushed them into the holes on the rim. After a few minutes they were held tight enough to hold against the turning of the spanner.
