Making a start on my Burrell SCC......
Page 1 of 4 1, 2, 3, 4  Next
Post  TimV on Sun 09 Nov 2014, 1:45 pm
TimV
Number of posts : 123
Re: Making a start on my Burrell SCC......
Post  lynnr on Sun 09 Nov 2014, 1:58 pm
Excellent!!
Number of posts : 2969
Post  Simon B on Sun 09 Nov 2014, 10:25 pm
Hi Tim
Your paint job looks amazing, I've just assembled kits at the moment and am a bit nervous about starting the paint job and even more so about the linning.
Well done.
Simon B
Number of posts : 126
Post  TimV on Sun 09 Nov 2014, 11:07 pm
Hi Simon.
Painting is all in the preparation, just take your time and you will be fine, however the lining can be a bit more tricky !!. Fortunatley over the years I have had a bit of practice buying various well worn model traction engines that I have stripped down and repainted.
TimV
Post  ChriX on Tue 11 Nov 2014, 7:13 pm
Looking good Tim, great to see another SCC builder on here Smile
ChriX
Number of posts : 90
Post  Simon B on Tue 11 Nov 2014, 11:14 pm
Hi Tim
When lining up your front axle have you used a Beugler or masked up? What's the best method of lining? I've read some conflicting views and can't make my mind up on the best way forward.
Simon B
Post  mikero on Tue 11 Nov 2014, 11:34 pm
There is a third alternative Simon, vinyl stencils, its how I did most of the fancy corners on my Foden.
Number of posts : 254
Post  TimV on Wed 12 Nov 2014, 1:34 pm
Hi Simon.
I used fine line masking tape for front axle (Tamiya or Jammydog tape) which I find is alot easier for small areas, just takes a long time to set up tape, and remember that its best to get tape off as soon as you have painted so as to prevent ripping.
Cheers Tim
TimV
Post  mikero on Wed 12 Nov 2014, 3:17 pm
There is a point at which the tape comes off clean, too soon and whiskers of paint come off with it, to late and the line cracks. Do some test runs on a spare sheet of metal.
A few more bits done !!
Post  TimV on Fri 26 Dec 2014, 5:17 pm
TimV
Post  Road loco on Fri 26 Dec 2014, 5:33 pm
Looking very nice well done, merry Xmas,
Road loco
Post  TimV on Fri 26 Dec 2014, 5:36 pm
TimV
Post  Tony King on Fri 26 Dec 2014, 6:18 pm
WOW! That's a beautiful paint finish you're achieving Very Happy Well done indeed!
The standard of the build & painting of these engines is "impressive" to say the least!!
Great to see your progress!
Post  ChriX on Sat 27 Dec 2014, 2:13 pm
Looking excellent Tim. I like your black hubcaps, I am still undecided on mine so currently half are black and half are bare steel.
ChriX
Post  TimV on Sat 27 Dec 2014, 3:14 pm
Many thanks to everyone for your positive comments
TimV
Post  TimV on Thu 26 Feb 2015, 6:44 pm
Tender painted in Burrell Crimson Lake and lined
Hornplate assembly
TimV
Post  phil gomez on Thu 26 Feb 2015, 8:03 pm
Hi TimV.
Now that is a work of art Tim, well done.
Keep up the good work.
Phil.
phil gomez
Post  TimV on Thu 26 Feb 2015, 8:23 pm
Thanks Phil. I thought I would have a go at hand painting the Hornplates and Tender with a view to spraying them if it all went wrong, but using the Craftmaster Coach Enamel and a Purdy brush I was quite impressed with the finish so thats how its goin to stay now !!. Just hope I can acheive the same sort of finish on belly tanks etc...
TimV
Post  Tony King on Thu 26 Feb 2015, 9:17 pm
Excellent paint job, so good to see some pictures of a SCC coming together!!
Post  ChriX on Mon 25 May 2015, 10:48 am
Question... I see you have put your hornplates together permanently (i.e. painted over all the nuts so it all looks good). I have held back from sorting all this on the basis it all needs to come apart to go on the boiler. I'd very much like to start bolting stuff together purely because there are bits everywhere, so how much does actually need to come apart to get the boiler in?
ChriX
Post  TimV on Mon 25 May 2015, 3:23 pm
In reply to your question, in theory the boiler should fit between the assembled hornplates but if not then I will have to loosen the bolts slightly and then when all is fitted back together again repaint them !! bit of a pain I know but like yourself wanted to start putting it together. may also have to loosen assembly for crankshaft alignment, but im of the opinion that if the 2nd shaft tube and the axle tube are bolted to the hornplates then theres not going to be much of movement to play with. I made sure that when I bolted it all together it was on a perfectly flat surface (kitchen worktop is good for this). All will become clear when I get a boiler !!!
Cheers Tim
TimV
Post  Tony King on Mon 25 May 2015, 5:34 pm
I think you will find that when you assemble onto the boiler, it's a lot easier if everything is "loose", get your boiler/horn plate bolts in place, then use crank shaft alignment tool & any flat surface & spacers etc etc to align everything up as you go round tightening all the various bolts up!!... Even then, (if My builds were anything to go by!) you'll probably still find a reason to unbolt everything anyway, so My advice don't paint nuts n bolts till you have a complete engine sitting on the floor!!
Sorry to give You this news, as I know how infuriating it is mucking up posh paint work!!
regards,
Post  ChriX on Tue 26 May 2015, 9:38 pm
Cheers both. I'm going to keep all the bits apart for now - there's going to be a lot of fun building up as soon as the boiler arrives!
ChriX
Post  storey on Tue 26 May 2015, 10:18 pm
I too have parts everywhere, roll on boiler delivery!
storey
Number of posts : 46
Post  Jim the Shovel on Tue 07 Jul 2015, 12:57 pm
Now that's a paint job to be proud of. Nice work.
The colours you've used are similar to what I've got in mind.
Black and orange because they are Harley colours and look good with green as a contrast.
Jim the Shovel
Number of posts : 100
