Tender try cocks
Tender try cocks
Post  MrStationHouse on Fri 07 Nov 2014, 10:41 pm
Have people been able to get these to work without leaking?
Or have you just sealed them up?
Number of posts : 313
Re: Tender try cocks
Post  lynnr on Sat 08 Nov 2014, 7:22 am
My replacements (batch one production run) all had oval holes so would never lap in. I have not got round to making new larger centres yet to make them work. So I am still on the original shabby ones. Or just fill them in.
I use a float to check level.
Number of posts : 2950
Post  Tim Watson on Sat 08 Nov 2014, 10:33 am
Ditto.
Number of posts : 559
Post  MrStationHouse on Sat 08 Nov 2014, 11:36 am
I think a little silicon is the plan then!
With best wishes
Post  Rickster on Wed 12 Nov 2014, 7:54 pm
Yes mine do. I drilled them out and made new spouts by putting a thread on the outlet and used old brass five lever lock keys - drilled tapped then heated and bent to shape.
I do use mine all the time when filling up it helps to have them open to release air as the water flows into the back tank - just works for me, not suggesting it's the best way.
Post  IanL on Wed 12 Nov 2014, 10:04 pm
Silicone was the answer to mine I thought they would not work but they did but could not stop them leaking. I have a float gauge in the tender to show the water level. This also allows the air to escape when filling.
