grub screw cyinder block
Post  Richard on Mon 13 Oct 2014, 9:28 pm
hi what do you stick grub screw in the Cylinder Block wich take the cladding as i cant find in instruction
thanks richard
Richard
Number of posts : 98
Re: grub screw cyinder block
Post  lynnr on Mon 13 Oct 2014, 9:57 pm
Hi Richard.
Use some PTFE tape on the threads or gasket sealant.
Number of posts : 2963
Post  Richard on Thu 16 Oct 2014, 8:14 pm
thanks Very Happy
Richard
Post  Brian M on Fri 17 Oct 2014, 8:58 pm
Hi Richard,
For a lasting seal (in my experience) you are best using green hermatite sealant directly on to the thread of the grub screw. Otherwise the PTFE tape will blow after a few steams, even when coated with graphite paste.
ATB
Post  lynnr on Fri 17 Oct 2014, 9:24 pm
That's strange. Mine has survived two full rally and road run seasons and testing during first year.
Post  Brian M on Sat 18 Oct 2014, 9:48 am
Well you are lucky then as I know of quite a few that have blown.
Post  Capricorn1 on Sun 19 Oct 2014, 5:29 pm
PTFE tape is old hat these days, I've seen some people wrap so much around the threads you'd think they were bandaging up a partially severed finger.
Loctite 567 thread sealer or similar.
Capricorn1
Number of posts : 77
Post  bjwlancashire on Wed 22 Oct 2014, 10:24 am
No problem with my grub screws either and Blackbeard is always working hard!!!
Post  Vapor on Wed 22 Oct 2014, 3:18 pm
I used Loctite 567 on my 4.5" Foden SWB 3 years ago and its been great, don't be tempted to use one of the lesser spec "Loctites" as remember your working with pressurised steam so the boiling point of the water will be way over 100c in fact at 120 psi you'll have a water temp of 172 dec so be careful steam doesn't take any prisoner's.
