Done it! First run on air
Post  MrStationHouse on Tue 19 Aug 2014, 7:24 am
Brilliant, first run on air. It took me a while to iron out the leaks, notably/ through the starting valve, but once I had done that it went fairly easily just needing a hand on the flywheel to get it going.
There is a knock which can be heard, this is the LP eccentric strap/rod end hitting the water pump drive (water pump not yet fitted) and either needs the end of the rod trimming or the drive turning down a little.
Number of posts : 313
Re: Done it! First run on air
Post  Tony King on Tue 19 Aug 2014, 7:53 am
Looking very nice, so good when things start to move on their own!! Exciting times!!
Post  bjwlancashire on Tue 19 Aug 2014, 11:09 pm
Well done Simon, another milestone for yet another builder.
