Build so far
Page 3 of 7 Previous  1, 2, 3, 4, 5, 6, 7  Next
Re: Build so far
Post  Crazy_jim on Fri 27 Feb 2015, 6:52 pm
That's what I'm thinking. If it's not perpendicular to the block I'm going to be in the hurt locker. I've seen what a misaligned crankshaft can do to the piston conrod on a 4". Don't be there when it happens!/don't be that guy. afro
Crazy_jim
Re: Build so far
Post  Mike King on Fri 27 Feb 2015, 7:17 pm
Crazy_jim wrote:That's what I'm thinking. If it's not perpendicular to the block I'm going to be in the hurt locker. I've seen what a misaligned crankshaft can do to the piston conrod on a 4". Don't be there when it happens!/don't be that guy. afro
yeah, its just not worth the hassle, especially after the care you have taken with the rest of it. I used to build car engines, and have seen what happens!😤
Number of posts : 310
Re: Build so far
Post  Crazy_jim on Sat 07 Mar 2015, 6:53 pm
A few shots of what's assembled before it all comes apart to fit the cladding.
Thought I could fit with hornplates on........ Negative.
Crazy_jim
Re: Build so far
Post  Mike King on Sat 07 Mar 2015, 7:51 pm
Thats really looking great! Did you have any joy with the bearing cap?
Re: Build so far
Post  Crazy_jim on Sat 07 Mar 2015, 8:52 pm
No reply as yet from STW. I will prob ring them next week if I don't get an answer.
I've had to strip everything back down again in order to fit the cladding. The rear piece wouldn't fit with horn plates in situ.
I will visit b&q or whoever has large jubilee clips tomorrow afternoon to hold them in place before fitting brass bands. Bit of fettling required for a snug fit.
Crazy_jim
Re: Build so far
Post  Crazy_jim on Sat 07 Mar 2015, 8:56 pm
Binned it for the night!
Crazy_jim
Re: Build so far
Post  Mike King on Sat 07 Mar 2015, 9:06 pm
Oh, heĺl i have it all to come!😕
Re: Build so far
Post  Tony King on Sun 08 Mar 2015, 9:12 am
Good to see the most important element sitting in the foreground on the "work" table. Very Happy
Great pictures!!
Re: Build so far
Post  Mike King on Sun 08 Mar 2015, 11:03 am
Just a curiosity question: are you going to line your wheels or leave them?
Re: Build so far
Post  Crazy_jim on Sun 08 Mar 2015, 4:36 pm
I'm in two minds at the moment. As I've said throughout the thread it's an agricultural wagon as opposed to a showmans etc. most people do line wheels/tender etc but I'm not normally a conformer I usually do opposite. Hence my livery isn't the standard burrell plum etc.
Crazy_jim
Re: Build so far
Post  Crazy_jim on Tue 24 Mar 2015, 8:32 pm
Just as a bit of an update. I recieved an email from Steve at STW this afternoon. After some measuring with calipers etc it turns out my bearing housings for
the crankshaft are a fraction on the small side and will need to be opened out with a file. (Contrary to the instructions saying to not do this)
New alignment tool in post and some fettling with a file to follow!
Crazy_jim
Re: Build so far
Post  Mike King on Wed 25 Mar 2015, 7:42 am
Thats a good result, excellent!
Front Wheels
Post  Pitpup on Sun 29 Mar 2015, 8:14 am
Hi, just a quick question, I was wondering what you did with the front wheels spoke inner nuts, did you try to make them look like rivet heads or just leave them as plan nuts. I have had some advice about forming false rivet heads but still remain undecided.
Thanks.
Pitpup
Number of posts : 108
Re: Build so far
Post  Mike King on Sat 04 Apr 2015, 10:00 am
Just a mundane question. Did you paint the mating surface of perch to smokebox, or leave it as bare metal?
Mike.
Re: Build so far
Post  lynnr on Sat 04 Apr 2015, 12:33 pm
Always paint as mating surface is not perfect so dampness will get in.
Number of posts : 2950
Re: Build so far
Post  Mike King on Sat 04 Apr 2015, 1:00 pm
Thanks very much. Dilemma solved.
Front wheel rivets
Post  Crazy_jim on Thu 09 Apr 2015, 10:28 pm
I didn't bother trying to make the nuts on the front wheels look like rivets. By the time I'd painted two coats primer/ two coats base coat and two coats of top coat the nuts look almost round now anyway.
The question regarding mated faces has already been answered but yeah any metal to metal surface needs protecting from good old H2O.
Crazy_jim
Cladding
Post  Crazy_jim on Thu 09 Apr 2015, 10:31 pm
Mmmmmm cladding. What a headache. I guess no matter how good your template each boiler will be subtly different. It took a bit of trimming but I'm there now.
Crazy_jim
Cladding
Post  Crazy_jim on Thu 09 Apr 2015, 10:46 pm
Another picture of the cladding firmly in place. Not the best picture but you can see the rear piece trimmed and firmly attached with the man hole cover fitted.
Crazy_jim
Firedoor
Post  Crazy_jim on Thu 09 Apr 2015, 10:51 pm
I boobed my original firedoors and the pins being too heavy handed. Luckily Steve sent me some new pins but I then realised I'd damaged the doors too so I made some new doors.
The whole lot took some filing and fitting and some more filing and more fitting but the end result is some smooth operating doors. A wee lick of paint and I'm all set to refit the hornplates and line them up onto the cylinder block etc.
Crazy_jim
Re: Build so far
Post  Mike King on Fri 10 Apr 2015, 9:05 am
Thats looking absolutely superb! My next kit is smoke box etc, so i have a long way to go yet. Seeing your build gives me loads of inspiration. Mike
Re: Build so far
Post  Mike King on Fri 10 Apr 2015, 4:22 pm
Hi, although i recently ordered same paint for smokebox, chimney and brass door plate. Plastikote no longer make the red satin. I tried autotec matt, its too orange. Can you suggest where i can get red satin? I have trawled the internet with no success. Any ideas would be welcome.
Re: Build so far
Post  Tony King on Sat 11 Apr 2015, 8:34 am
You could always try red brake calliper paint, it's very high temperature paint & I'm sure will survive on the smoke box, also You could have a look at coloured exhaust manifold paint, such as stuff Frost supply!
Re: Build so far
Post  Mike King on Sat 11 Apr 2015, 8:53 am
Hi Tony,
Thanks for your reply. I have looked at the frost and also caliper paint. The frost is matt and the caliper paint is high gloss. I was really looking for a similar sheen to the plastikote woodstove satin finish. I have thought about powder coating that part. I have also considered using the woodstove paint on that in black, as i have seen that on full sized engines. What do you reckon?
Re: Build so far
Post  Tony King on Sat 11 Apr 2015, 12:51 pm
I guess on agricultural engines, it was more traditional to have black on the name ring... That's what I have on mine!
Re: Build so far
